Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Aftermarket cooler for GeForce 8800 series cards?
Forum Overclocking : Cooler and Heatsinks - Aftermarket cooler for GeForce 8800 series cards?
Are there any available aftermarket coolers for the 8800 GTX? I'd prefer air as I'm not yet ready to go for water cooling.
Thanks for the help!
Sponsored Links
it is better to have water cooling and not need it, than to need water cooling and NOT have it
Reply to surf2di4
Can't see any yet. I'm waiting for a decent one which can reduce the noise!
Reply to mkaibear
Agreed, yet I don't OC my VGA's so I'm not looking for extreme temp reduction. Rather, I'm looking for reduced noise.
Reply to SPARTAN-117
Quote :
I found this one.
Would that work? I am skeptic... that thing doesn't even have a fan
Reply to stefx
Hey guys, I just ordered a 8800GTS :D and might look for a AM cooler if the stock cannot cut it (although not planning to OC for now). It appears that the choice of fan is left up to you by Thermalright. IMHO this looks to be a champ of a cooler (will look further at it).
Reply to PeaShooter
According to thermalright, it's designed just for the 8800. They have another design close to that one and it performs very well. It can be used passively or with a fan. This new one says to be used with a 92mm fan or smaller. As for me, I would use a fan adapter with a 120mm. :D
Reply to AdamBomb42
Nice find AdamBomb42. I think this is the first air cooler for 8800. Been waiting for it.
Now where can i find one? :twisted: Cant find it nowhere. :twisted:
Reply to sarsoft
Quote :
With a vertical typical computer, isn<t that cooler's weight going to "pry" the card , bend the connections at the slot? It looks fairly heavy
Reply to stefx
Looks like a beast... Although, IMHO, I think its an over glorified paper weight with the heatpipes routed like that. I can't see it actually doing a good job.
My $.02
What about the RAM sinks? and IC's? The stock HSF is for just about every major component on the 8800. If you went with the Zalman you would have to get seperate sinks for everything else on the card. Cost would be not worth it. I'll wait for a better HSF that cools everything the stock one does but better and without haveing to use thermal tape.
Reply to Maglin
The heatpipes are routed like that so you can have the cooling fins on the back of the card.
Reply to AdamBomb42
Quote :
My $.02
Its very light, I have the normal hr-03 on my x1900xtx, idle temps in the 30s load in the 50s a good 20C better than stock, while being silent :)
Reply to wimcle
As far as I know the HR-03 comes with ramsinks that are quite similar to what Zalman packages with their vga card hsfs. I don't see why the HR-03Plus would not come with ramsinks. Also there is something else... Zalman doesn't have a hsf compatible with the 8800 series.
Reply to function9
try doing some research first and you'll find out its one of the best vga coolers out there...
Thermalright's HR-03 Is A VGA Cooler Gorilla!
Reply to IcY18
Quote :
True indeed.
Reply to sarsoft
Well that was a nice review of the HR-03. I did some research and found that it did come with ram sinks. Not to sure how well it will cool the 8800's RAM but I'm sure it's should be close to Nvidia's HSF solution. I retort my previous statment. The specs for it didn't say anything about ram sinks nor are any shown in it's picture, so I figured it was just a HS only. I think I might just pick this beauty up when it becomes available for my GTS.
Reply to Maglin
Quote :
You tell him to do research but you only have one source to back yourself up of doing any research. LoL.
Reply to MingoDynasty
He wasn't proving a point (which would be nice to site multiple sources.)
He was stating that if you assume a cooler sucks, you very well could be wrong.
http://www.legionhardware.com/Bench/Thermalright_HR-03/Test.png
Here are some more reviews:
http://www.tweaknews.net/reviews/thermalright_hr-03/
http://www.pcper.com/article.php?aid=340
http://www.legionhardware.com/document.php?id=592
Can even use two for SLI/CF:
http://www.tweaknews.net/reviews/thermalright_hr-03/img/4.jpg
Reply to tool_462
Quote :
Yes i told HIM to do the research, not me...i wasn't going to link him every site with which there is a review for the HR-03...so i helped him out a little and backed up my point that the HR-03 is a quality VGA cooler by linking a obviously credible site which did a great review of the HR-03...
do you disagree with this...?
so since you need more proof it can easily be done by clicking Here, otherwise known as google...
Reply to IcY18
Quote :
Those look massive. From what i can tell they take two slots and not counting the 92mm fan ---yickes---.
Reply to sarsoft
Well, many cards are able to run with no fan. If you have it in wrap around setup then you wont take up any more space than any other cooler. How they have it set up they still get that middle PCI slot if needed.
Reply to tool_462
That setup looks awesome problem is that if your going to by a high end cooler your most likely buying it for a high end video card or maybe a slight chance you would get it for complete silence on a low-mid range card. Problem is that you can't hope to passively cool a 8800GTX or GTS safely without pushing it near its thermal limit even with excellent case airflow. so you have to stick a fan on there which takes up a third or fourth slot since the cooler takes up atleast 2 to begin with. either way if you are using two the these babies its obviously shown a particular setup will allow you to use atleast 1 pci slot, which is all you would hope for if you were going to Sli with stock cooling anyway.
A problem i already see is that it looks like there is definitely not enough room for the memory on that board, graphic cards usually already cut it close enough to the memory slots when the cooler is on the bottom, this one looks as though you wouldnt be able to set it up that way with the cooler on top..
Reply to IcY18
HR-03 can run x1900xtx with no fan and kept it near stock cooling. I don't know if it could handle a GTS at stock core clock with no fan or not. Probably though.
http://images.tomshardware.com/2006/11/14/thermalrights_the_hr-03_is_a_vga_cooler_gorilla/image005.gif
It's hot yes, but silent too. I've seen x1900 series cards topping over 100C, ATI's spec calls for keeping it under 120C I think.
Reply to tool_462
I've heard nothing but good about the Thermaltake HR-03...but what kind of fan couple it with?
Reply to MrScarface
It's not out yet, but here's what I've found about the HR-03 Plus: At Overclock.net
I spoke to Coolerguys.com on the phone and he told me that the Thermalright HR-03 PLUS should be in his shop by wen/thur. and on his site Fri/ Sat.March 1-2 for about 48.00.
Hope this helps!!!
I also contacted Arctic Cooling awhile back and they finally got back to me stating they were indeed also coming out with a VGA Cooler for the 8800 Series. No other info. available.
Lets hope this Cooler vents out the back like there other VGA coolers
Reply to christophertech
it doesn't vent out like the stock cooling on the 8800GTX and X1950XTX, depending on how you arrange the fan you can either have it blow directly north or south unless you were to manually configure it otherwise.
Not to take anything away from the HR-03 its still the best vga cooler around.
Reply to IcY18
ATi's software from what i know will begin to throttle back at 100C, i would never recommend running your card in the 90s and most certainly you would begin to damage the card at >100C temps. Take note that some cards run hotter than others and even though a X1900XTX can run hotter than normal most other ATi cards would be dead when going above 100C
Reply to IcY18
Quote :
there is about 1.7" from the base of the cooler to the mb, dimms stick up about 1.25"
Reply to wimcle
My home made solution has my 8800GTX idling at 49c and loading after hours of gaming at just 57c. I am also running 650core and 2030mem.
http://i179.photobucket.com/albums/w305/jimjohn_2007/Picture030.jpg
Reply to RobsX2
Quote :
Being that many cards run over 90C using stock cooling with no overclocking and good case airflow, ATI must not be worried about them running at those temps.
Maybe "most" other cards aren't able to handle 100C+ but we arent talking about those cards right now are we :wink:
Robs: Nice setup, is that PC P&C PSU? Or is the exhaust from the Tuniq blowing into the PSU fan?
Reply to tool_462
Quote :
Well the only card i know that could run at 90C and be comfortable would be a X1900XTX, maybe an X1800XT which is what i have and but it doesn't hit 90C and i have terrible airflow and i would never want it to hit 90C.
The X1900XTX is the hottest most power demanding card i know of, the R600 may surpass its power demand but i don't think it will eclipse the amount of heat it runs at...
So i'm not sure what cards run over 90C on stock cooling...
Reply to IcY18
Quote :
Yeah thats the 750watt PC Power and Cooling PSU with the 60amp single 12v rail :wink:
The exhaust from the Tuniq is flowing out tward that giant 120mm Case exhaust fan.
Reply to RobsX2
Sorry I didn't mean many cards as in many models, I meant many x1900xt/x's run that hot.
I agree though, hell if I would ever let anything in my rig run 100C, let alone 60C 8)
I was just saying that ATI spec allows it, so it must be fairly safe.
Reply to tool_462
There are 1174 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
