a problem with cryptographic?
Last response: in Windows 2000/NT
Anonymous
Security Expert
Archived from groups: microsoft.public.win2000.security (More info?)
Hello!
I have this problem; when I try to import a certificate appears the
following error:
"The private key that you are importing might require a cryptographic
service provider that is not installed on your system."
I've been looking for this problen in microsoft database but the only thing
that I've found I need to install the last service pack.
I've tried with this solution but the problem continues.
Thanks!
More about : problem cryptographic
Anonymous
Security Expert
You should also post this in the "Microsoft crypto" newsgroup. It sounds
like the operating system does not support the CSP [ not a built in one]
that was used with the certificate and therefore you need to install it as
provided from the manufacturer. If this is for a smart card the info below
may be pertinent from the link below. --- Steve
http://www.microsoft.com/technet/security/topics/identi...
A Cryptography Service Provider (CSP). This facilitates communication
between the device and the smart card. The CSP must be signed by Microsoft,
or it will not work on Windows 2000. Typically, a CSP is provided by the
manufacturer of the Smart Card Reader-for example, a GemPlus reader would
use a GemPlus CSP, a Schlumberger CSP would use the Schlumberger CSP, and so
on.
"J. Alberto Gonzalez" <jalbertogonzalez@airlan.es> wrote in message
news:u9FqgsBQFHA.576@TK2MSFTNGP15.phx.gbl...
> Hello!
> following error:
> thing that I've found I need to install the last service pack.
> Thanks!
Ask the community
