Archived from groups: microsoft.public.win2000.security (More info?)
Good morning,
This past Friday, I was having problems with my DNS. The short version is
that I ended up deleting our zones and am in the process of resolving that
problem. However, when I went to do this last Friday, a DNS server from
another organization showed up as the SOA for the newly created zone. I had
been receiving alerts most of the day that this ip address was doing a nmap
udp port sweep. I talked to the vendor this morning and they had no idea.
For more details, I'm providing the post to the dns forum where I'm trying
to resolve the issue of being able to recreate the zone. It seemed like we
were getting compromised.
DNS Post:
We have three DCs--DC1, DC2, and DC3. We had an AD Integrated zone for our
forward lookup zone. On DC3, the zone showed as a secondary zone, so I tried
to change the type to an AD integrated zone (right-click, properties,
etc...), but it wouldn't allow it. I didn't write down the actual message,
but I was given two options: use the current zone or use the AD zone.
Neither option would work. I decided to delete the zone, thinking that since
the zone was a secondary zone that it would just die and I would be able to
create an AD zone or that the AD zone would replicate over. That didn't
work. In fact, the AD zone disappeared on both DC1 and DC2.
Next, I panicked and posted my previous thread ("Urgent!!!" ).
I have just tried creating a Primary zone on DC1 and created secondary zones
on DC2 & DC3. Then I ran Netdiag /fix. I wish I could say that I saved the
results to a text file, but I didn't. I did get it printed, though. The DNS
test shows it failed (surprise) with several FATAL errors trying to recreate
dns entries. I had set the zone to allow dynamic updates, accept updates
from all servers and had manually entered NS, A and PTR records for all DCs.
At this point, all zones have once again disappeared--the primary on the
master and the two secondary zones.
See the link below which may help in rebuilding you dns zones. I suggest
that unless your organization requires otherwise, use only AD integrated
zones, do not allow zone transfers to other dns servers if not needed[ this
is not needed for AD integrated dns zones and never select "to any"], and
require secure updates unless you have a need to not use that. You may also
want to post in the win2000.dns newsgroup. Keep in mind that if you delete
an AD dns zone, that zone will be totally deleted from Active Directory and
not just that server. You also need to have some patience when rebuilding
your dns as replication will not be immediate to other dns servers/domain
controllers. Another alternative could be an authoritative restore of Active
Directory from a recent System State backup of a domain controller for AD
integrated dns zones. --- Steve
"C Hall" <someone@microsoft.com> wrote in message
news:%233giL7BRFHA.904@tk2msftngp13.phx.gbl...
> Good morning,
> had
> nmap
> DNS Post:
> tried
> since
> to
> zones
> DNS
> recreate
> DCs.
> Any clues would be appreciated.
Steven,
Thanks for the post. It's looking like a rebuild of one DC (not a FSMO role
holder). I didn't allow enough disk space and that's causing problems. Aside
from that, there are a bunch of errors in the logs, I can't open ADU&C to
follow the guidance of the the dns group (Kevin). Armed with new info, I
don't think this is a security problem at this point. I will look at the
links below. Thanks again.
"Steven L Umbach" <n9rou@nospam-comcast.net> wrote in message
news:uQgM2LFRFHA.1528@TK2MSFTNGP09.phx.gbl...
this
also
and
Active
> http://support.microsoft.com/?kbid=260371 -- see To repair the Active
> Directory DNS record registration
> http://support.microsoft.com/defau [...] s%3B291382 ---
DNS
> best practices.
> > Good morning,
is
that
> > had
> > nmap
idea.
trying
we
> > DNS Post:
our
> > tried
message,
> > since
> > to
> > zones
the
> > DNS
> > recreate
> > DCs.
OK. Sounds good. The reason you can not open ADUC is probably because of a
dns problem in that the domain controller _srv records can not be found.
When you ping your domain name you normally should be retuned the IP address
of a domain controller and the same goes for nslookup. --- Steve
news:uxOaLXFRFHA.3788@tk2msftngp13.phx.gbl...
> Steven,
> role
> Aside
> this
> also
>> delete
> and
>> rebuilding
> Active
> DNS
>> best practices.
>> > Good morning,
> is
> that
>> > had
>> > nmap
> idea.
> trying
> we
>> > DNS Post:
> our
>> > tried
> message,
>> > since
>> > able
>> > to
>> > zones
> the
>> > DNS
>> > recreate
>> > updates
>> > DCs.
>> > the
> Steven,
role
It is nearly impossible to do that with a small domain.
The installation (DCPromo) claims it needs 1 Gig for
AD but only needs (less than) 100 MBytes.
This default size will handle thousands of users easily.
> Aside
As Steve has said, you likely have DNS problems.
DNS servers do NOT "advertise" nor do they set themselves
up so either you or some other admin must have done this.
Check your DNS first -- it is the KEY to making AD work:
DNS for AD
1) Dynamic for the zone supporting AD
2) All internal DNS clients NIC\IP properties must specify SOLELY
that internal, dynamic DNS server (set.)
3) DCs and even DNS servers are DNS clients too -- see #2
4) If you have more than one Domain, every DNS server must
be able to resolve ALL domains (either directly or indirectly)
Do not be so fast on saying you did not have a security problem.
You said "the IP" of some alien host
1. showed up as NS when you attempted to redefine the zone
for your AD
2. your zone on one AD had changed to secondary (a DC/DNS will
not do this, as you discovered when attempting to revert it)
3. you said "the IP" had been seen as the origin of nmap etc scans.
That all sounds to me like you have a security issue.
You perhaps had poisoned cache allowing the bad NS to show up
when the zone redefinition was attempted. You perhaps had a DNS
zone under outside control (sort of implies a DC also) and being used
perhaps for injection of some machine within network communications.
To recover fast, you can always collect together the netlogon.dns files
from each of the three DCs. These you would merge into a single file
in which you would need to adjust the SOA record so that it represents
only one of the NS (DCs) records.
You could use this as a std primary on one DC and secondary on the
other two, in order to bootstrap AD functionality between DCs.
Then change to AD integrated and make sure that you have set it to
allow only secured dynamic updates (and to protect against cache
pollution).
Roger Abell
Microsoft MVP (Windows Security)
MCSE (W2k3,W2k,Nt4) MCDBA
> Steven,
role
Aside
> this
and
> also
delete
> and
rebuilding
servers/domain
> Active
AD
> DNS
> > best practices.
> > > Good morning,
> is
> that
from
I
> > > had
> > > nmap
> idea.
> trying
like
> we
> > > DNS Post:
> our
> > > tried
> message,
> > > since
able
> > > to
didn't
> > > zones
> the
The
> > > DNS
> > > recreate
updates
all
> > > DCs.
the
Roger and everyone,
Thanks for the replies.
Roger,
That was my first thought--DNS cache poisoning. The one reason I thought
that it just may be an internal configuration problem is that the zone I'm
using is already in use as an Internet domain space--a mistake on my part. I
talked to the third party to whom the address belongs and they are a ISP and
it belongs to one of their name servers. After running a trace, they said
they saw our address trying to do a zone transfer, which with the ids still
logging nmap sweeps it appears this is still going on. I'm trying to follow
the suggestions from Kevin in the DNS forum, but the fustrating thing is
that I'm told by my boss to not touch it until after Friday when our
auditors leave. He's concerned that any work on the domain will effect one
of our mission specific applications, but there's no way it can be. People
have local user accounts on that machine and have mapped drives to what they
need on that server. I'm no guru, but he just doesn't understand MS
networking. I'm stuck at the moment. How long can I leave this situation
limping? 60 days (tombstoning limit)?
"Roger Abell" <mvpNOSpam@asu.edu> wrote in message
newsx3mxuIRFHA.3628@TK2MSFTNGP12.phx.gbl...
> for your AD
> pollution).
> Roger Abell
> > Steven,
> role
> Aside
to
suggest
integrated
> > this
> and
> > also
> delete
Directory
> > and
> rebuilding
> servers/domain
> > Active
> AD
tp://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B291382 ---
> > DNS
> > > best practices.
> > > > Good morning,
version
> > is
resolving
> > that
> from
zone.
> I
> > > > had
a
> > > > nmap
> > idea.
> > trying
> like
> > we
> > > > DNS Post:
for
> > our
I
> > > > tried
properties,
> > message,
zone.
that
> > > > since
> able
> > > > to
> didn't
secondary
> > > > zones
saved
> > the
> The
> > > > DNS
> > > > recreate
> updates
> all
> > > > DCs.
> the
Well, I am not tightly envisioning your current state, but the
tombstone timelimit really mostly only impacts your ability
to restore AD authoritatively.
The nmap part is perhaps the most troubling.
Is the transfer that ISP reports seeing a transfer to or transfer
from their DNS server ? I assume they meant from theirs if
they said they see your DNS server IP attempting a transfer.
I will try to find time today to bump over to the DNS NGs
and catch up on your thread there.
However, I really do not understand why that ISPs DNS
is involved in transfer attempts (with your DNS servers?),
and I certainly do not see why you cannot flush its mention
out of the zone. At the very least, you could go into the
zone properties and explicitly list the NSs with which
zone tranfser is allowed, and the boss should be none the
wiser on that one as you would list all of and only your
DNS servers' IP. Also, consider a rule in the firewall
to kill packets to/from that IP. Keep in mind that with
AD integrated zone the SOA record on each DC will be
indicating itself. Check them all.
Is the ISP's DNS server one of those where they allow
their customers to manage zones through some interface?
If so, then I could perhaps understand its being "injected"
into your zone's authority.
Roger Abell
newsS$oyyORFHA.688@TK2MSFTNGP10.phx.gbl...
> Roger and everyone,
> Roger,
I
and
still
follow
they
> > for your AD
> > pollution).
> > Roger Abell
> > > Steven,
> > role
> > Aside
> to
I
the
> suggest
> integrated
needed[
> > > this
any"],
> > and
may
> > > also
> > delete
> Directory
> > > and
> > rebuilding
> > servers/domain
of
> > > Active
for
> > AD
Active
> > > DNS
> > > > best practices.
> > > > > Good morning,
> version
> > > is
> resolving
> > > that
> > from
> zone.
> > I
> > > > > had
doing
> a
> > > > > nmap
no
> > > idea.
I'm
> > > trying
> > like
> > > we
> > > > > DNS Post:
> for
> > > our
so
> I
> > > > > tried
> properties,
> > > message,
> zone.
> that
> > > > > since
be
> > able
> > > > > to
> > didn't
> secondary
> > > > > zones
> saved
> > > the
though.
> > The
> > > > > DNS
to
> > > > > recreate
> > updates
for
> > all
> > > > > DCs.
on
> > the
Thanks for the info, Herb. And the input RE: Subject in the DNS forum...I
hit panic mode;->
"Herb Martin" <news@LearnQuick.com> wrote in message
news:eoLxyPGRFHA.3288@TK2MSFTNGP14.phx.gbl...
> > Steven,
> role
> > Aside
to
> DNS for AD
> netdiag /fix
> ...or maybe:
> dcdiag /fix
> (Win2003 can do this from Support tools):
> nltest /dsregdns /serverC-ServerNameGoesHere
> http://support.microsoft.com/kb/q260371/ >
> Ensure that DNS zones/domains are fully replicated to all DNS
> servers for that (internal) zone/domain.
> Also useful may be running DCDiag on each DC, sending the
> output to a text file, and searching for FAIL, ERROR, WARN.
> Single Label domain zone names are a problem Google:
> [ "SINGLE LABEL" domain names DNS 2000 | 2003 microsoft: ]
At the moment, my dns zone won't stay created. I'm going to try to get the
f/w rule created. See the thread: "active directory integrated zone delted,
can't create secondary zone" for more dns details...
news:u9k$uBPRFHA.2744@TK2MSFTNGP10.phx.gbl...
> Roger Abell
> > Roger and everyone,
> > Roger,
I'm
part.
> I
> and
> still
> follow
one
People
> they
> > > for your AD
files
> > > pollution).
> > > Roger Abell
> > > > Steven,
FSMO
> > > role
problems.
> > > Aside
ADU&C
> > to
info,
> I
> the
> > suggest
> > integrated
> needed[
> > > > this
> any"],
> > > and
> may
> > > > also
you
> > > delete
> > Directory
> > > > and
> > > rebuilding
> > > servers/domain
> of
> > > > Active
> for
> > > AD
> Active
> > > > DNS
> > > > > best practices.
> > > > > > Good morning,
> > version
> > > > is
> > resolving
> > > > that
server
> > > from
> > zone.
> > > I
> > > > > > had
> doing
> > a
> > > > > > nmap
> no
> > > > idea.
> I'm
> > > > trying
seemed
> > > like
> > > > we
> > > > > > DNS Post:
zone
> > for
> > > > our
zone,
> so
> > I
> > > > > > tried
> > properties,
actual
> > > > message,
> > zone.
thinking
> > that
> > > > > > since
> be
> > > able
> > > > > > to
> > > didn't
> > secondary
> > > > > > zones
> > saved
> > > > the
> though.
> > > The
> > > > > > DNS
> to
> > > > > > recreate
> > > updates
> for
> > > all
> > > > > > DCs.
primary
> on
> > > the
First, your internal zone using an internal name the
same as a public name doesn't really interact with
cache poisoning.
Holding your zones, it distinct from the resolution
you do for clients (beyond those zones) and poisoning
is worked through that resolution.
Thanks for the lesson, Herb.
news:enUGOrRRFHA.248@TK2MSFTNGP15.phx.gbl...
I'm
part.
> cache poisoning.
news:#mv9kyRRFHA.3496@TK2MSFTNGP12.phx.gbl...
Sure but it still didn't solve you real issue. <grin>
thought
> I'm
> part.
> > cache poisoning.
I hear you....it seems that one of the main problems is that on our F/W
there was a statement to NAT our dns server ip to an outside address and
that's why it was trying to transfer the public zone to our private zone.
Not sure how/when that happened, but am glad to know what needs to happen to
resolve the problem.
Chris
news:%23uvuRUTRFHA.3704@TK2MSFTNGP12.phx.gbl...
> thought
zone
> > I'm
> > part.
> > > cache poisoning.
news:#UW5licRFHA.244@TK2MSFTNGP12.phx.gbl...
to
Ok, that sounds like it might fix it or at least change
the symptoms to something simple.
