Tom's Hardware > Forum > Home Theatre > HDTV > Using IR transmitter/receiver system for multiple components
Forum Home Theatre : HDTV - Using IR transmitter/receiver system for multiple components
Archived from groups: alt.tv.tech.hdtv (More info?)
I currently have a X-10 Pyramid IR Transmitter/Receiver system that I
use so that I can use my HD TIVO with a couple televisions and control
it from both TV's. As well, this system is used to control a
component switchbox as well as a D-VHS JVC deck. The units are all in
a cabinet together so in general the universal remote can easily
control all these units through the one IR system. At times though
the signal won't reach all units and I have a IR transmitter that is
plugged into the receiver that I mounted in a place that it can reach
most components well but then it sometimes controls the TV next to the
components which I don't want.
My question, is there a adaptor or maybe another IR
transmitter/receiver system that I can use that can hold up to 3 IR
transmitter extension wires. That way I could mount the transmitter
directly in front of each component by the IR window. I know I could
easily just buy a couple extra receivers but was hoping there was a
cheaper solution. Thanks for any suggestions.
Sponsored Links
"MarkW" <markwco*remove to reply*@comcast.net> wrote in message
news:1vb3h09kpg6cb5j5hm1qn1dl0btc798d47@4ax.com...
I've been using Audioplex [hardwired] IR repeaters.
To add extra IR emitters to those, I just splice them together at the unit's
output..
So, I think a 1/8" mono Y-adapter could be used to add more emitters to your
pyramid receiver.
Anyway, here is a dual IR emitter:
http://www.asihome.com/cgi-bin/ASI [...] ogno=X286M
Reply to David
There are 1157 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
