Hi I am in the process of overclocking my system, but I have some stability problems. To put my problem simply, my system memory runs fine past 800Mhz, but when my bus speed is raised and I try to use the 667 MHz option (a divider of 6) my system won't post past a certain (240) bus speed, even though my memory is at 800Mhz. Specs are in sig. Right now I am using the 533(8 divider) option. My proc and mobo can reach past 240MHz, and my memory can reach past 800, but even if I drop my CPU multiplier to let it equal 2000(original speed) and 667 option, I can't post, even though my memory would be at less than 800MHz! Am I missing something?
