Tom's Hardware > Forum > Overclocking > General Discussions > Help! Overclock E4300 with ECS or S3 motherboard?
Forum Overclocking : General Discussions - Help! Overclock E4300 with ECS or S3 motherboard?
I am looking to bump up my cpu just a bit.
I just got the MB+CPU cheap combo at Frys for $160
E4300 and ECS PT890T-A
I have read many post about OC with anthing "BUT" this crappy board.
Here is my goal..... Arrow
I would to OC this cpu with the least amount of money $$$ put in.....
I dont' need to OC to 3.8Ghz or 4.3Ghz....i need it to last about 5yr or more
with little or no money put into it.... I am cheap... Wink
Quesiton?
1. Can you OC with this ECS board? or if needed, just buy a better heatsink w/ fan? To what speed is stable and safe?
2. What memory should i use? Am i OK with 5400, 667mhz any brand? or Do i have to get 800mhz?
3. I hope to OC the cpu at a range of 2.2Ghz to <3.0Ghz.? what is the setting? How do i do that? Do I have to change the board? or buy another Heatsink?
Sponsored Links
I believe theres a pin-mod for that board that will up the fsb to 266 and give you a 2.4ghz chip. Google the name of your MB with "pin mod" and you should get some links. Good luck 8)
Reply to Pax2All
There are 926 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
