Admin / Domain Admin rights problem
Last response: in Windows 2000/NT
Archived from groups: microsoft.public.win2000.security (More info?)
Hi,
I'm using SBS2000 as my primary DC.
I have a problem - the Administrator account cannot access 'HKLM' keys in
the registry. I've been told it is because the Administrator is not a member
of the Domain Admins group. Except, accoring to SBS Admin console, it is.
Furthermore I can't change the permissions for HKLM using the registry
editor. I need to give the account access to HKLM but don't know what else
to do - help!
Thanks
Andy
Hi,
to do - help!
Thanks
Andy
More about : admin domain admin rights problem
Evidently you can view the security settings on HKLM
Who/What account/group does have full permissions?
You will need to use an account that does have the ability.
Roger Abell
Microsoft MVP (Windows Security)
"Andy Roxburgh" <rallybob@hotmail.co.uk> wrote in message
news:uamLJ1$eFHA.744@TK2MSFTNGP14.phx.gbl...
> Hi,
member
> to do - help!
> Thanks
> Andy
Roger Abell
> Hi,
member
> to do - help!
> Thanks
> Andy
Actually I can't view the security settings - a message pops up telling me I
can change them but not view them... except when I try to change them it
won't let me do that either.
So I can't see what accounts have full permissions!
Andy
"Roger Abell" <mvpNOSpam@asu.edu> wrote in message
news:uQCeGDCfFHA.1948@TK2MSFTNGP12.phx.gbl...
> Roger Abell
> > Hi,
in
> member
is.
else
> > to do - help!
> > Thanks
> > Andy
Andy
> Roger Abell
> > Hi,
in
> member
is.
else
> > to do - help!
> > Thanks
> > Andy
Make sure that you are logging on as the administrator account and not some
renamed administrator which is sometimes used as a domain account. The
command "net user administrator" will display group membership. Also verify
that domain admins is a member of the administrators group for the domain as
it is possible for it to be removed. You should also run a full malware scan
on your server being sure to use the latest definitions from your vendor.
Also some "protection" packages can block access to the registry I am told.
You may want to boot into safe mode to see if that helps. Subinacl is a tool
that can be used to view and change file and registry permissions at the
command line if need be. However it is very powerful and I would not use it
unless you have a full image type backup of your server or you are very
confident that you are using the right command possibly from trying it on a
test computer first. Group Policy can also be used to manage registry
permissions via computer configuration/Windows settings/security settings -
registry though you need to be careful doing such and should unlink the
Group Policy when done and needs to be linked to the proper OU where the
computer accounts are. Improper use of file/registry permissions via Group
Policy can cause performance problems in the domain. --- Steve
http://www.microsoft.com/downloads/details.aspx?FamilyI...
-- subinacl
http://www.jsifaq.com/SUBR/tip8700/rh8724.htm -- Group Policy to manage
file/registry permissions.
news:uClPEQIfFHA.3936@TK2MSFTNGP14.phx.gbl...
> I
> Andy
>> Roger Abell
>> > Hi,
> in
>> member
> is.
> else
>> > to do - help!
>> > Thanks
>> > Andy
-- subinacl
> I
> Andy
>> Roger Abell
>> > Hi,
> in
>> member
> is.
> else
>> > to do - help!
>> > Thanks
>> > Andy
Related ressources
- Giving Admin Rights to my Windows XP user - Forum
- user needs admin rights to run app - Forum
- Roaming Profiles & Admin Rights ? - Forum
- logon to DC without Admin rights - Forum
- Revoke local admin rights - Forum
Hi Steven,
some
I get (exactly as output) :
Logon Script
User Profile
Home Directory
Last logon 6/30/2005 2:00pm
Logon Hours Allowed All
Local Group Memberships
*Account Operators
*Administrators
*Backup operators
*Server Operators
*Print Operators
Global Group Memberships
*Exchange Services
*Domain Admins
*Domain Users
*Enterprise Admins
*Exchange Domain Serve
*Group Policy Creator
*Backoffice Internet U
*Scheme Admins
>Also verify
as
I checked this with the SBS Admin console and it appears to be OK.
Just tried a full AV scan and it consistently locks up half way through -
not a great sign!
Just ran MS Antyspyware beta and it's clean; will try a different AV scanner
and try again.
told.
Will try this at the weekend - the server's in use at the moment.
>Subinacl is a tool
it
a
Thanks! Have used it to show the HKLM permissions. Typing
subinacl /key HKEY_LOCAL_MACHINE /display
I get :
+KeyReg HKEY_LOCAL_MACHINE
/control=0x0
/owner =builtin\administrators
/primary group =system
/audit ace count =0
/perm. ace count =4
/pace =system ACCESS_ALLOWED_ACE_TYPE-0x0
CONTAINER_INHERIT_ACE-0x2
Key and SubKey - Type of Access:
Full Control
Detailed Access Flags :
KEY_QUERY_VALUE-0x1 KEY_SET_VALUE-0x2
KEY_CREATE_SUB_KEY-0x4
KEY_ENUMERATE_SUB_KEYS-0x8 KEY_NOTIFY-0x10 KEY_CREATE_LINK-0x20
DELETE-0x10000
READ_CONTROL-0x20000 WRITE_DAC-0x40000 WRITE_OWNER-0x80000
/pace =builtin\administrators ACCESS_ALLOWED_ACE_TYPE-0x0
Full Control
DELETE-0x10000
/pace =everyone ACCESS_ALLOWED_ACE_TYPE-0x0
Read
KEY_QUERY_VALUE-0x1 KEY_ENUMERATE_SUB_KEYS-0x8 KEY_NOTIFY-0x10
/pace =restricted ACCESS_ALLOWED_ACE_TYPE-0x0
Read
and this compares to HKEY_USERS which I do have access to as follows:
+KeyReg HKEY_USERS
/control=0x0
/audit ace count =0
/perm. ace count =4
Full Control
DELETE-0x10000
Full Control
DELETE-0x10000
Read
Read
To me it looks fine; but there's definitely something wrong somewhere
because it won't show HKLM permissions etc from regedit!
Do you think I should try
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=systems=f
Ironically the reason I'm going through all this is so that I can create a
ghost image - I'm using Veritas IDR and it's not playing ball.
So I can't easily ghost the server before making changes.
settings -
Group
I don't appear to have the 'registry' item available under 'security
settings'....
It's not looking good is it??!
Andy
Hi Steven,
some
Logon Script
User Profile
Home Directory
*Account Operators
*Administrators
*Backup operators
*Server Operators
*Print Operators
*Exchange Services
*Domain Admins
*Domain Users
*Enterprise Admins
*Scheme Admins
>Also verify
as
not a great sign!
and try again.
told.
>Subinacl is a tool
it
a
I get :
/control=0x0
/audit ace count =0
/perm. ace count =4
Full Control
DELETE-0x10000
Full Control
DELETE-0x10000
Read
Read
+KeyReg HKEY_USERS
/control=0x0
/audit ace count =0
/perm. ace count =4
Full Control
DELETE-0x10000
Full Control
DELETE-0x10000
Read
Read
settings -
Group
settings'....
Andy
Hmm. From what I can tell it looks like subinacl shows that administrators
have full control of HKLM. I am at a loss as why you can not edit it. I
always use regedt32 for Windows 2000 so you may want to try that if you have
not yet. If it was my computer I would not use subinacl until I had an image
backup. As far as Group Policy - registry you will not see that in Local
Group Policy but it should show in Domain Controller Security Policy if SBS
has such. If you can not get for antivirus to work try using the SysClean
utility from Trend Micro [see links below]. Just download Sysclean and the
pattern file [after unzipping] into a common folder to run from - no
installation is involved. --- Steve
http://www.trendmicro.com/download/dcs.asp
http://www.trendmicro.com/download/pattern.asp
"Andy Roxburgh" <spamplease@hotmail.co.uk> wrote in message
news:usMh4EYfFHA.3904@TK2MSFTNGP14.phx.gbl...
> Hi Steven,
> some
> Logon Script
> User Profile
> Home Directory
> *Account Operators
> *Administrators
> *Backup operators
> *Server Operators
> *Print Operators
> *Exchange Services
> *Domain Admins
> *Domain Users
> *Enterprise Admins
> *Scheme Admins
>>Also verify
> as
> not a great sign!
> scanner
> and try again.
> told.
>>Subinacl is a tool
> it
> a
> I get :
> /control=0x0
> /audit ace count =0
> /perm. ace count =4
> Full Control
> DELETE-0x10000
> Full Control
> DELETE-0x10000
> Read
> Read
> +KeyReg HKEY_USERS
> /control=0x0
> /audit ace count =0
> /perm. ace count =4
> Full Control
> DELETE-0x10000
> Full Control
> DELETE-0x10000
> Read
> Read
> settings -
> Group
> settings'....
> Andy
> Hi Steven,
> some
> Logon Script
> User Profile
> Home Directory
> *Account Operators
> *Administrators
> *Backup operators
> *Server Operators
> *Print Operators
> *Exchange Services
> *Domain Admins
> *Domain Users
> *Enterprise Admins
> *Scheme Admins
>>Also verify
> as
> not a great sign!
> scanner
> and try again.
> told.
>>Subinacl is a tool
> it
> a
> I get :
> /control=0x0
> /audit ace count =0
> /perm. ace count =4
> Full Control
> DELETE-0x10000
> Full Control
> DELETE-0x10000
> Read
> Read
> +KeyReg HKEY_USERS
> /control=0x0
> /audit ace count =0
> /perm. ace count =4
> Full Control
> DELETE-0x10000
> Full Control
> DELETE-0x10000
> Read
> Read
> settings -
> Group
> settings'....
> Andy
It sure is starting to sound like a malware based inhibition
of registry tool access.
Roger
"Steven L Umbach" <n9rou@nospam-comcast.net> wrote in message
news:e%233zjHbfFHA.1412@TK2MSFTNGP09.phx.gbl...
have
SBS
> > Hi Steven,
> > some
> > Logon Script
> > User Profile
> > Home Directory
> > *Account Operators
> > *Administrators
> > *Backup operators
> > *Server Operators
> > *Print Operators
> > *Exchange Services
> > *Domain Admins
> > *Domain Users
> > *Enterprise Admins
> > *Scheme Admins
> >>Also verify
domain
> > as
vendor.
through -
> > not a great sign!
> > scanner
> > and try again.
> > told.
> >>Subinacl is a tool
the
use
> > it
on
> > a
> > I get :
> > /control=0x0
> > /audit ace count =0
> > /perm. ace count =4
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Read
> > Read
> > +KeyReg HKEY_USERS
> > /control=0x0
> > /audit ace count =0
> > /perm. ace count =4
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Read
> > Read
a
> > settings -
the
> > Group
> > settings'....
> > Andy
Roger
have
SBS
> > Hi Steven,
> > some
> > Logon Script
> > User Profile
> > Home Directory
> > *Account Operators
> > *Administrators
> > *Backup operators
> > *Server Operators
> > *Print Operators
> > *Exchange Services
> > *Domain Admins
> > *Domain Users
> > *Enterprise Admins
> > *Scheme Admins
> >>Also verify
domain
> > as
vendor.
through -
> > not a great sign!
> > scanner
> > and try again.
> > told.
> >>Subinacl is a tool
the
use
> > it
on
> > a
> > I get :
> > /control=0x0
> > /audit ace count =0
> > /perm. ace count =4
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Read
> > Read
> > +KeyReg HKEY_USERS
> > /control=0x0
> > /audit ace count =0
> > /perm. ace count =4
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Full Control
> > DELETE-0x10000
WRITE_OWNER-0x80000
> > Read
> > Read
a
> > settings -
the
> > Group
> > settings'....
> > Andy
I was wondering about such. Hopefully using Sysclean and trying from safe
mode will give a clue. I also understand that some "internet protection"
packages can also block access to/protect the registry and users often do
not realize such or forget about it when they install those type programs.
I have not used such a program myself. Many of the antivirus programs are
going far beyond just malware detection and removal which I guess is a good
thing if a user understands/remembers what is being done to their
omputer. --- Steve
news:ud47DukfFHA.2156@TK2MSFTNGP14.phx.gbl...
> Roger
>> administrators
> have
> image
> SBS
>> the
>> > Hi Steven,
>> > some
>> > Logon Script
>> > User Profile
>> > Home Directory
>> > *Account Operators
>> > *Administrators
>> > *Backup operators
>> > *Server Operators
>> > *Print Operators
>> > *Exchange Services
>> > *Domain Admins
>> > *Domain Users
>> > *Enterprise Admins
>> > *Scheme Admins
>> >>Also verify
> domain
>> > as
> vendor.
> through -
>> > not a great sign!
>> > scanner
>> > and try again.
>> > told.
>> >>Subinacl is a tool
> the
> use
>> > it
>> >> very
> on
>> > a
>> > I get :
>> > /control=0x0
>> > /audit ace count =0
>> > /perm. ace count =4
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Read
>> > Read
>> > +KeyReg HKEY_USERS
>> > /control=0x0
>> > /audit ace count =0
>> > /perm. ace count =4
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Read
>> > Read
>> > create
> a
>> > settings -
>> >> the
> the
>> > Group
>> > settings'....
>> > Andy
omputer. --- Steve
> Roger
>> administrators
> have
> image
> SBS
>> the
>> > Hi Steven,
>> > some
>> > Logon Script
>> > User Profile
>> > Home Directory
>> > *Account Operators
>> > *Administrators
>> > *Backup operators
>> > *Server Operators
>> > *Print Operators
>> > *Exchange Services
>> > *Domain Admins
>> > *Domain Users
>> > *Enterprise Admins
>> > *Scheme Admins
>> >>Also verify
> domain
>> > as
> vendor.
> through -
>> > not a great sign!
>> > scanner
>> > and try again.
>> > told.
>> >>Subinacl is a tool
> the
> use
>> > it
>> >> very
> on
>> > a
>> > I get :
>> > /control=0x0
>> > /audit ace count =0
>> > /perm. ace count =4
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Read
>> > Read
>> > +KeyReg HKEY_USERS
>> > /control=0x0
>> > /audit ace count =0
>> > /perm. ace count =4
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Full Control
>> > DELETE-0x10000
> WRITE_OWNER-0x80000
>> > Read
>> > Read
>> > create
> a
>> > settings -
>> >> the
> the
>> > Group
>> > settings'....
>> > Andy
news:uWxgv1lfFHA.1284@TK2MSFTNGP14.phx.gbl...
good
> omputer. --- Steve
Ey, brave new world now, and again coming, isn't it Steve ?
Half of the ground rules will probably have shifted by your return.
Have a great time up north Sir, an kiss the short sweet Summer once
for me, ok?
ra
good
> omputer. --- Steve
for me, ok?
ra
I guess time waits for no one as technology marches on though sometimes it
is nice to get away from it all. I will be around for a couple of weeks
t. -- Steve
news:uyCFyUsfFHA.1044@tk2msftngp13.phx.gbl...
>> programs.
> good
>> omputer. --- Steve
> for me, ok?
> ra
t. -- Steve
>> programs.
> good
>> omputer. --- Steve
> for me, ok?
> ra
FYI, the problem eventually got fixed by using the reset.cmd script and
SubInAcl.exe.
Andy
SubInAcl.exe.
Andy
Related ressources:
- Forumsetting admin rights in xp???
- ForumChanged Admin Password on domain ......problems.
- ForumDomain Admin could not log on to DC
- ForumNT domain admin account locks out
- ForumCreate account on Windows Server R2 with domain admin Rights
- ForumDomain admin users audit
- ForumTCP/IP changes without Admin rights
- ForumXP SP2 requires Admin rights for USB Flash Drive (Mass Sto..
- Forumaccidentally removed domain admin rights in security of a ..
- Forumdomain admin group of parent domain is NOT a member domain ..
- ForumUser with domain admin rights
- ForumAdmin rights without option to install software
- ForumParallel and com ports not appearing in device manager
- ForumUser access rights problem
- ForumUSER ACCESS RIGHTS TO WINDOWS 2000 SERVER FOLDER
- More resources
