Yes No
Ads
Tom's Hardware > Forum > Home Theatre > HDTV > Mitsubishi Red Color Problem
Forum Home Theatre : HDTV Mitsubishi Red Color Problem
Archived from groups: alt.tv.tech.hdtv (More info?)
my friend has a 65" mitsubishi hd 1080 series tv (bought 1999 - 2001).
when the color level is raised beyond about 1/6th of the way up, the
reds "splotch" - not sure what the technical term is. it is like a
bright spot appears within the red and will grow as the color level is
raised.
in order to mitigate this red splotching, he has to lose so much
color his picture looks pretty bad.
he's had a tech out to look at the tv and they didn't know much.
can anybody give me an idea of what is happening here (is it a
defective red gun?) so I can help out my friend?
tia...
Reply to Anonymous
"Skeets" <skillet3232@yahoo.com> wrote in message
news:756b5cd1.0408090022.5eb5e0d6@posting.google.com...
> raised.
> tia...
There is a model number on the back of the set.
Is the growth of the splotch to the right of the red in the image? Your
description is not very clear.
Leonard
Reply to Anonymous
Possible the crt{s} are becoming weak and you are seeing solarization due to
loss of emission within the crts.
"Leonard Caillouet" <no@no.com> wrote in message
news:CYIRc.16385$Bb.199@lakeread08...
> > raised.
> > tia...
> Leonard
Reply to Anonymous
> raised.
> tia...
RED video smearing to the right on high contrast scenes (or high color).
Turning the contrast or brightness down eliminates the problem. Can be
caused by weak RED CRT, low screen voltage or RED drive set too high.
Reply to Anonymous
This is a seemingly common problem with Mitsubishi sets. A friend had 2 Mitsus
(1 tube and 1 RPTV) both exhibited this problem, and it usually gets worse over
time.
Reply to Anonymous
I also had this problem with a 65" Mits I got two years ago. The problem
showed up when I used the NTSC tunner built into the set. DVD's were fine.
The problem was eliminated with a DirecTV HD tuner. Now I use the
tuner in the Zenith HDSAT 520 for all Signals and the picture is great. The
tuner outputs 1080i over component video for all inputs; DirecTV, OTA
(HD and SD), and cable.
Hope this helps.
Mike Jones
> raised.
> tia...
Reply to Anonymous
"Steve Grauman" <oneactor1@aol.com> wrote in message
news:20040809122722.19243.00002974@mb-m04.aol.com...
Mitsus
over
> time.
So what was the diagnosis and the solution? What were the model numbers?
How old were the sets?
Leonard
Reply to Anonymous
Beats me. But I know the tube needed to be repaired in regards to this exact
problem at least twice, most recently about 2 months ago.
I don't know off-hand. The tube is a 34-inch, I believe, and from the
mid-1990s. The RPTV is a smallish unit (as far as RPTVs are concerned), under
60-inches and about 3 years old. It's an analog 4:3 set.
Reply to Anonymous
news:20040809140951.19192.00003062@mb-m06.aol.com...
exact
under
Just curious. I have been servicing Mitsubishi television sets since 1979
and CRT problems are rare, particularly with the larger direct view CRTs
(that unfortunately they no longer make). With RPTV, tube problems are also
rare, though a few sets have had bad focus assemblies that cause CRT
failures or will confuse a servicer into thinking that the CRT is bad.
Many CRTs will "flare" near the end of their useful life (in terms of
emission at the cathode). The only service that is possible on a CRT for
this problem is sometimes "restoration" or "rejuvenation". If the set was
serviced twice for the problem it was likely a video drive problem rather
than the actual CRT, particurly at the age described.
It is certainly not a typical problem for mitsubishi sets, IME.
Leonard
Reply to Anonymous
sorry for the not clear descriptions. it doesn't matter where the red
is - it can be lips, a shirt, a car - doesn't matter. the splotching
occurs all over the screen - wherever the red is.
i think the "solarization" response is probably the one that most fits
what is happening here - but if anyone has any other input, please do
tell...
tia...
skillet3232@yahoo.com (Skeets) wrote in message news:<756b5cd1.0408090022.5eb5e0d6@posting.google.com>...
> raised.
> tia...
Reply to Anonymous
I'll take your word for it - as a tech. I just know that this same family had 2
different Mitsu TVs exhibit pretty severe problems involving red "splashing"
and "haloing", etc... and that the tube needed to be repaired twice in regards
to this problem. I've always found Mitsubishi TVs to be very red and it's kept
us from having one here at home, so I don't have any first-hand experience with
their reliability. However, the newer Platinum Series sets with the 9-inch CRTs
are very attractive and I wonder if an ISF calibration would have as much
effect on one of the Mitsus as it has had on the Sony and Pioneer Elite RPTVs
I've seen.
Reply to Anonymous
news:756b5cd1.0408091236.d980128@posting.google.com...
> tell...
Not much more input unless you can supply a model number...
Leonard
Reply to Anonymous
- 0 +
>raised.
>tia...
Sounld like it might be the "Red Push" as it was once called. Home
theatre spot forum has a thread on this.
Here is a link to one thread, it a list a parts you can get a radio
shack to solve this, if it is the "Red Push". cost under $10
http://www.hometheaterspot.com/hts [...] Post446860
Reply to fred
Red Push does not cause bleeding, it's a term used to refer to sets that have
very "warm" color temperatures, which consequently make reds look over
pronounced.
Reply to Anonymous
"fred" <nus@tenretni.moc> wrote in message
news:k33gh0t6cdv692e2h55st289mcgs6ho973@4ax.com...
Red push is a very slight shift in the color decoding toward red, giving
things a slightly more red tint. It would not be causing this kind of
problem, though it might exacerbate it.
Red push is a very overstated problem.
Leonard.
Reply to Anonymous
"Leonard G. Caillouet" <lcaillo_ns_@devoynet.com> wrote in message
news:%iORc.1394$zt3.1006@bignews5.bellsouth.net...
> Mitsus
worse
> over
> > time.
> Leonard
MGA had, 2 years ago on their proj tv's, a problem with a couple of auto
kinebias transistors shorting when the picture tube arced. That caused too
much brightness. If someone reduced the screens to compensate rather than
replacing the bad transistors that could cause the problem. "SCREEN control
too low"
Reply to Anonymous
"Jeff Rigby" <jeffg212@comcast.net> wrote in message
news:sOOdnejNkPHeIoXcRVn-rg@comcast.com...
> > Mitsus
> worse
> > over
> > > time.
numbers?
> > Leonard
too
control
> too low"
Correct and a good possibility since he said it was serviced more than once.
With a model number someone could have checked for more specific
information.
BTW, MGA was a trade name that is no longer. Mitsubishi has been Mitsubishi
Digital Electronics America for some time. Ironically, it is probably one
of the closest to being a US TV manufacturer that we have anymore.
Leonard
Reply to Anonymous
I find it to be a very BIG problem, as I'm sensitive to color shifts and the
red push that Mitsu sets tend to exhibit bothers me. However, I've seen Sony
and Pioneer Elite sets tuned to *perfection* despite their own color issues,
after an ISF calibration. Any serious owner who has invested thousands of
dollars into a display should pay to have the calibration performed.
Reply to Anonymous
news:20040810194743.15036.00001302@mb-m02.aol.com...
the
Sony
issues,
Many people confuse improper gray scale tracking with color decoding
problems. Once properly aligned, red push is a minor issue. If you still
don't like it you should not tolerate it. You should, however, understand
where it comes from and its relative significance. Also, Mitsubishi has
largely eliminated the red push problem and has included RGBCYM settings in
the consumer menus on the last two chassis designs, making it possible to
set the color to virtually anyone's preference.
Leonard
Reply to Anonymous
>problems
I'm generally pretty good at picking out color-decoding issues, but I may have
made a mistake or two in my identification.
I agree...to an extent. How minor it is depends on how prevalent it is and how
bothersome I find it. However, Sony sets tend to have a *very* minor red push
with a much more pronounced white/blue push and I've seen those issues
corrected entirely with calibration. Pioneer's Elite sets (among my favorites)
tend to come off a little yellow/green occasionally (thanks in large part to a
native color temp. of 6500k) but I've seen them corrected to perfection as
well.
>If you still
Of course not. The entire reason why so many TV manufacturers can exist is
because they all have different pictures to cater to different viewers.
However, we should all recognize that Sony, Pioneer, Mitsubishi and even
Hitachi all make a very high-quality RPTV and that with calibration any of them
can be set to near-perfection and throughly even the playing field.
Reply to Anonymous
news:20040810202521.06719.00002896@mb-m13.aol.com...
> >problems
have
how
push
favorites)
to a
> well.
> >If you still
them
I agree completely, only I'd not consider Hitachi a near competitor but an
equal to any of them. The higher end Toshiba sets have some nice qualities
as well. Each has subtle pros and cons and these can vary model to model.
Of course, these generalizations are for CRT based products and may not
carry over to LCD and DLP based sets.
Leonard
Reply to Anonymous
news:20040809223806.25422.00003137@mb-m29.aol.com...
have
> pronounced.
It isn't the color temperature (grayscale), it is the color decoder
emphasizing red. Sometimes it is done to compensate for a grayscale that is
too blue, so that skin tones remain a pleasant pink. It can cause bleeding
of red if the saturation (color) is turned up high enough to give the proper
levels of blue and green.
I do not know if this is what the original poster was experiencing.
Reply to Anonymous
I've never seen the color alone cause bleeding in a tube or RPTV.
Reply to Anonymous
>as well.
>as well.
I really, really like Toshiba's Cinema Series HD-tubes and I very much like
their RPTVs as well. All of these are good companies.
Of course. I personally don't really like Plasma, LCD or DLP sets, my
preference still sits with tube and CRT-Lens based RPTVs, so I rarely ever
bring the others into the conversation.
Reply to Anonymous
There are 2035 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 23 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
Top experts
