Hi there! I used to be quite savvy with PC hardware but after I got a new job I was just focusing on software and troubleshooting, etc... Go figure everything changes when you turn your back for a moment :wink:
I'm grasping at straws for hardware recommendations and hope you can help! In a nutshell I'm trying to design a very basic HTPC that lets me:
- Rip my DVD collection to the HDD then Play them on the living-room TV
- Do the same for my CDs and MP3's
- Display misc pictures and videos (taken from digital cam, downloaded, etc..)
- All this needs to be done via a remote for ease-of-use and to clear up clutter in the living room (kb/m only when absolutely needed). I was thinking IMon since it apears to be the most popular.
- No need to play/record tv. I have a PVR/tuner box through the cable company that I have zero complaints with
- Sound Level is an issue but I'm savvy enough to replace high-noise fans with low-noise fans and do any tweaks necessary after-the-fact if needed.
Motherboard: Looking at Full-ATX, not a single clue what direction to go with this. This is a major dilema for me
Video Card: Component Video or S-Video is needed. I'll be upgrading to high-def in about a year but for now I have a CRT with component/s-video/composite connections with a max res of 480p. If I have to upgrade in a year sobeit but if there are options for component as well as high-def I am more than all-ears. Idealy it will be used for video scaling, upconverting, and pushing the DVD's to the tv without stuttering. Gaming not an issue but if I can get gaming in a card for only a bit more $$ then I will.
CPU: Intel, AMD, don't overly care. Again, gaming not a priority but if I can get good gaming performance without doubling the cost, I will.
Case: Thinking Silverstone 16/20m or Thermaltake Bach/Mozart. Ahanix D4 and MCE601 look particularly nice as well.
RAM/Hard Drive/DVD: I can figure it out no problem but if you have good suggestions for suggested gear, I am all ears.
I really hope you guys can help - I've tried other forums with more than lack-luster results. I feel real stupid calling myself a geek all these years and now that I'm trying to get back into the swing of things I'm finding it almost impossibly hard to re-learn the new terms, formats, companies, tech, etc
- Jason
