Your power supply would work. Antec is a real solid company. My suggestion is that if you have the money try to go for a 750watt power supply. Thats if you have the money in your budget. You wont regret it because it leaves so much room for yourself in the future. You also wont run into instability problems if you over clock. That extra headroom will be nice. Also, I just wanted to say that I use this powersupply:
I LOVE it, its modular, 600watts and is running my system nicely. I have had ZERO issues with it since I bought it 6 months ago. For some reason its not on that list the guy posted... but my opinion is that its really good quality and on top of that its a beautiful piece of hardware : ). Good luck with your search!
The NeoHE is the same thing as the Corsair HX520, they're the exact same OEM manufacturer, exact same internals/components and they're both modular. I'd rate them the same except for the fact that I think the Corsair is built better.
If you're spending $120-140 you could easily get the Corsair HX620 somewhere else.
The 520 is enough for an 8800GTX, but I would recommend the 620.
With all the stuff you got plusupgrading to an 8800 vga card you need more watts or your going to run into stability issues i hope this may help you out.
