Tom's Hardware > Forum > CPU & Components > Sound Cards > Please suggest a good simple sound card.
Forum CPU & Components : Sound Cards - Please suggest a good simple sound card.
Hi guys.
I have a Asus P5B Deluxe with "AC97" & "ADIĀ® AD1988B 8-channel High Definition Audio"
The sound sucks. (really bad) I'll look for better drivers again.
Please suggest a low-profile PCI or PCIe-1x card that uses very little CPU power, easy to find drivers, as good as EAX (or whatever is most popular now), and works well with any game.
My speakers are just average (4 + sub), so I don't need a very high-end card.
Ok, thanks!
Sponsored Links
Creative Sound Blaster SB0570 Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
$28 shipped
http://www.newegg.com/Product/Prod [...] 6829102002
Reply to jaguarskx
Yeah, the audigy SE is a good choice, It doesn't have hardware acceleration (If you try to enable EAX or hardware acceleration, it either won't work or the sound will be weird) but it will make an enormous difference in music and the sound quality in games over on-board.
Reply to turboflame
- 0 +
Thanks for the suggestions!
It seems the Audigy SE is better than AC97.
Reply to enewmen
- 0 +
Creative Audigy 2.
Reply to XrayMan
- 0 +
Quote :
$28 shipped
Agreed, thats what I have in this rig. When you install the drivers I'd suggest NOT installing Creative's Media Source Go. Also if you use a Microphone then you'll have to set it in the mixer because it's not enabled by default.
Reply to alanman
There are 772 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
