I think the first is the one you want but you might check to see if the
other is working properly also.
Go to Line 220 left side for : Restore Open With on the Right Click
Also Check Line 241 right side for: Restore Choose Program - Open With
"MS Jordan" <msjordan@disney.net> wrote in message
news:Xns9614E929B1089msjordandisneynet@68.6.19.6...
> Suddenly I can no longer make a part of the "open with" feature work
> anymore.
> I can not longer add a program to the "open with" list or get the desired
> program to work when I browse to the program to work anymore.
> When I access the program thru the start menu or a shortcut the programs
> work just fine - it just when you right click and select the open with
> dialog
> Any idea's
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Since I only have a rudimentry knowledge of Registry thought I better ask a
couple of questions
Ref - Go to Line 220 left side for : Restore Open With on the Right Click
I compared the contents of my registery against what is in 220 and they
appear to be the same. I am making the assumption that if they are the same
there is no problem with that entry !
Ref- Line 241 right side for: Restore Choose Program - Open With
My - [HKEY_CLASSES_ROOT\Unknown\shell\openas\command]
Looks like this
Don't do any manual changing of the registry.
The files you have on your desktop ( Or where ever you saved them to ) will
do all the work.
Neither one will hurt your system.
Just do a right click and select merge.
Depending on which version of XP you are running you may get a security
warning.
If so , Click on Run.
If that warning doesn't appear there will be a question
about adding this information to the registry.
Click on Yes.
Some of these additions require a logoff or reboot before they take effect.
First check and see if your problem is solved, if not logoff and back on and
try again.
If still not corrected do a reboot.
"MS Jordan" <msjordan@disney.com> wrote in message
news:Xns9616F291B1BFFmsjordandisneynet@68.6.19.6...
> a
> couple of questions
> same
> Looks like this
> %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32
> \shell32.dll,OpenAs_RunDLL %1
> - 241 has a batch of hex code
> - since I am 30 years removed from understanding hex, should I past
> the hex code into the entry or is the above correct ?
> BTW - thanks for the help
You're welcome.
Thanks for the feedback.
Oldguy
news:Xns9619CBE9D7064msjordandisneynet@68.6.19.6...
> "Oldguy"
> Thanks for the help, don't know which one but one of them solved the
> problem
> Thanks for taking the time
> MS Jordan
