Hi, I'm building my first gaming PC, probably an AMD X2 3800 or 4200, and I'm now looking at monitors. Problem is I don't know much about what to look for. I'd like to have a flat screen monitor, but I've never used one before. With a little research I've learned that with LCDs you have to worry about native resolution, and if you use other ratios you may not get a great picture. A brief read of other threads has also implied to me that LCDs perhaps have other viewing issues, especially with games, which is what I'm wanting the computer for.
It's been years since I've had a high-powered machine, and the most advanced games I've played are probably NWN1 (without any of the expns), Deus-Ex, and Freelancer, and those I had to play on low display settings. So now I'm looking to be able to play Oblivian, NWN2, KOTOR, Guild Wars etc.
So, what do I need to look for in a monitor? I'm on a budget and would rather spend cash on RAM, CPU and GPU, so the cheaper the better for a monitor. Will a cheap LCD be OK as long as it has a decent native resolution? What other system stats do I need to look for? And what is the general verdict of the other gamers out there, will a cheap LCD do the trick for my needs? I don't need everything at max res and framerate with all the features on, but obviously I'd like it to be smooth and pretty as possible. If a CRT would be much better and cheaper I'd be willing to go that way.
Thanks in advance.
Thanks in advance.
