Archived from groups: microsoft.public.win2000.setup (More info?)
After receving various status codes and to a MS helpdesk
tech, it was recommended that I only run the repair
option from my W2K CD.
After running that option my computer no longer boots
clean. It defaults to a menu where I can select W2K
Professional aor W2K Professional setup. If I don't
select it coninutes to boot eventually asking for a boot
disk.
I have tried to recover my previous CFG.SYS but that
failed.
What is the procedure to get W2K to boot clean and
straight into the desktop?
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| disk.
| failed.
Thanks Dave.
I appreciate the assistance.
I will give it a shot.
Randy
>-----Original Message-----
>Edit boot.ini located in the root of the system
partition (usually C:\)
>boot.ini will be something like;
>[Boot Loader]
>Timeout=30
>Default=C:\$WIN_NT$.~BT\BOOTSECT.DAT
>[Operating Systems]
>multi(0)disk(0)rdisk(0)partition(1)\WINNT="Windows
2000" /fastdetect
>C:\$WIN_NT$.~BT\BOOTSECT.DAT="Windows NT Setup"
>Change it to; (note the 'default=' line must also
change. rdisk and
>partition values may be different for your system.)
>[Boot Loader]
>Timeout=30
>Default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
>[Operating Systems]
2000" /fastdetect
>Regards,
newsgroup.
helpdesk
boot
>| disk.
>| failed.
You're welcome.
Regards,
"Gladiator" wrote:
| Thanks Dave.
| Randy
