What exactly does the 4 pin 12v power connector do?
Last response: in Components
- Safe to use an 4-pin to 8-pin 12v ATX power connector? - Tech Support
- GIGABYTE 880GM USB3, 1 x 8-pin ATX 12V power connector, But I using 4 pin power connector. - Tech Support
- 4 pin ATX 12V power connector in 8 pin 12V ATX Motherboard? - Tech Support
- Can you use an ATX 12v 4-pin power connector on a 8-pin port? - Forum
- 4 pin 12V power connector for my new motherboard. Old motherboard has 8pin.o.O - Forum
- Can you use an ATX 12v 8-pin power connector on a 4-pin port? Forum
- SolvedDoes it matter what 8 pin i use for my CPU power connector? solution
- Solved24 pin power connector, powers on, add the 4 pin, does not. (Asrock 960GC-GS FX) solution
- Computer not powering on when 4 pin connector 12v cable is out Forum
- SolvedPCI-E Powercable 6pin vs PCI-E Powercable 6pin no connector: does the extra 12v hurt? solution
- SolvedIs it ok to connect two old smps 80mm fans in series by a 4-pin molex connector in 12v connection? solution
- SolvedMotherboard has 4-pin ATX 12v connector and CPU 8pin, Help... solution
- Does using an 8-pin CPU power connector on a 4-pin board result in less amperage? Forum
- SolvedM6 Gene - 4-pin 12V connector solution
- SolvedDoes this server motherboard use a standard EPS 12V 20 pin connector? Forum
- SolvedPSU - ATX 12v 4 - 8 pin connector? solution
- Power pin connectors not working. Jump starting the power pins does not work. What is the issue? solution
- my ga-f2a88x-up4 mother board has an 8 pin 12v atx connector do I need all 8 to run or csn I just use 4 pins? solution
- Solveddoes psu have 4 pin connector for amd apu solution
- SolvedCan I attach just one of the 12v 4 pin eps connectors from a 12v 8 pin eps adapter- solution
- More resources
Read discussions in other Components categories
Since it seems to tie in at least to some extent to that 4pin 12v connector, I figured I would try to find what it does.
