Tom's Hardware > Forum > CPU & Components > CPUs > Mem speed of kingston hyperx this correct?
Forum CPU & Components : CPUs - Mem speed of kingston hyperx this correct?
hi there..
i bought this system over the weekend would like to know,cpuz shows that my Kingston Hyper X DDR2 750mhz modules run at 333mhz is that correct?
Gigabyte DS3
Intel E6300
1GB Mem
Win XP
Sponsored Links
The stock frequency for E6300 is 266 MHZ, unless you are overclocking.
Reply to evongugg
Which CPU-Z tab are you looking at?
Reply to XMSYellowbeard
Quote :
hi there..
Gigabyte DS3
Intel E6300
1GB Mem
Win XP
They're supposed to run @ 375MHz, but if you aren't using SPD in the BIOS, it's probably set to 333MHz(5:4). :wink:
Reply to 1Tanker
There are 564 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
