Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > xp home networking group policy problem.
Forum Windows XP : Windows XP General Discussion - xp home networking group policy problem.
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.configuration_manage,microsoft.public.windowsxp.general,microsoft.public.windowsxp.network_web (More info?)
greetings!
i hope you guys can help me with this, since it seems to be no common
problem.
the thing is this: i have two pcs connect by a switch and the network is
fine, meaning
that both pcs are pingable, i can connect to the wan from eithe one and i
can even
access the shared files of one of them which, and here is the problem, alas
is not
working vice versa too.
having the xp home edition, which isn't shipped with the neccesary
administration
tools i had to improvise and use some old win nt apps to try and find out
what's
actually wrong with the laptop, being the pc whose network resources cannot
be
accessed. with the tool musrmgr.exe finally i found out that you can
actually specify
the user groups whom you want to give access to the system via a network.
since
on my laptop i don't even have the administrator group added to this setting
but on
the other pc i have all the groups i'm using, i hence think that this is it.
this is my
problem.
unfortunately the tool i used can only read the settings. so i'm left with
no application
whatsoever which could change this setting and let me use the network
properly already.
i really really hope you people can help me out with this.
thank you in advance!
lipsticks
Sponsored Links
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.general,microsoft.public.windowsxp.network_web (More info?)
On Fri, 11 Mar 2005 15:49:15 +0100, "poisonLipsticks" <none@nowhere.org> wrote:
>greetings!
>problem.
>fine, meaning
>can even
>is not
>administration
>what's
>be
>actually specify
>since
>but on
>this is my
>problem.
>no application
>properly already.
>lipsticks
Lipsticks,
With Windows XP Home, you have Simple File Sharing. With SFS, access to shares
is granted to the Guest account only.
<http://www.microsoft.com/downloads/details.aspx?FamilyID=87c0a6db-aef8-4bef-925e-7ac9be791028&DisplayLang=en>
With XP Home, you can temporarily disable Simple File Sharing by starting up in
"Safe Mode with Networking".
A Description of the Safe Mode Boot Options in Windows XP:
http://support.microsoft.com/?id=315222
With Simple File Sharing disabled, right click the desired folder, click Sharing
and Security, and share the folder. Then, click the Permissions button to
specify network access permissions, and click the Security tab to specify NTFS
file system permissions. A network user needs both permissions in order to
access the share.
For details how to set permissions:
http://www.practicallynetworked.co [...] /index.htm
Cheers,
Chuck
Paranoia comes from experience - and is not necessarily a bad thing.
My email is AT DOT
actual address pchuck sonic net.
Reply to Chuck
Have a read of this
http://support.microsoft.com/defau [...] 74&sd=tech
It doesn't addess the editing policy issue, but you will be able to share
files
Regards
Mark Dormer
"poisonLipsticks" <none@nowhere.org> wrote in message
news:d0sb5c$qv6$02$1@news.t-online.com...
> greetings!
> problem.
> fine, meaning
> can even
> alas
> is not
> administration
> what's
> cannot
> be
> actually specify
> since
> setting
> but on
> it.
> this is my
> problem.
> no application
> properly already.
> lipsticks
Reply to Anonymous
There are 1159 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
