Hi,
I've just bought a BFG Geforce 7800 GS and it doesn't work properly. I was previously using a Geforce fx 5700LE with no problems. I have installed the latest nvidia drivers.
When I boot up the screen display is knackered with odd bits of colour every - looks a bit like the matrix actually.
When it's booted, any attempt to change the colour setting from low or the resolution from 800x600 stops the graphics card outputting any signal at all and I have to restart in safe mode.
This is a brand new card so should be fine - does anyone have any ideas?
Thanks
I should also add I have a 500W PSU
Hi,
Thanks
