sounds and Audio Devices problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I'm having a little problem with my sounds in control panel. Sometimes when
I change one of the sound events with another sound, I get the error message:
an expection occured when trying to run "C:\Windows\System32\shell32.dll,
Control_RUNDLL "C:\Windows\system32\MMSYS. CPL," @0". Sometimes the ending
number is @1 or sometimes I get a message instruction cannot be read or
written to memory.
I don't know what could be causing this. No virus or spyware are on my
computer and I upgraded to SP 2, thinking that would help.
Please someone help me!
Byte
1,199
Try running the particular sound file in Sound Recorder or one of your
Media apps before selecting it as an event sound. It may be corrupt or in
the wrong format. You can do a Search for the file or use Windows Explorer
then double click it. If it is a valid sound file, your default player will
play it
for you or you can Open it with your selection.
> written to memory.
G
Guest
Guest
Sorry, that didn't work. Thanks for the advice though:)
> play it
> > written to memory.
G
Guest
Guest
I don't know if this is the reason or not, but I turn off Windows Media
Player as the default player for .wavs and I don't get anymore error
messages. I just left nothing as the default player of .wavs. Could Windows
Media Player have caused this trouble?
> written to memory.
G
Guest
Guest
Nope, I was wrong:( Someone help me, please!
> > written to memory.
