Archived from groups: microsoft.public.win2000.setup (More info?)
(problem in thread posted earlier today in win2000.general forum dated
8/4/04 by mistake)
I developed a problem with being unable to initiate loading of the Win2K
operating system earlier today. I was helped by Pegasus, who asked me
to test whether I could load the OS with a floppy that contained my
boot.ini (from my hdd), ntldr, and ntdetect.com (both copied from my
Win2000 disk) . It worked. I tried copying those files back to my hard
drive c:\ drive but I still require the floppy to be present in order
for the loading to take place. If the floppy with its files is not
there, I hang right after the PCI assignments are displayed during the
boot posting.
Does anyone have any ideas where I can go from here to be able to load
from my hard drive without having to have the floppy in place? Are
there any BIOS settings that may have been tweaked that I should check?
(ASUS P4PE mb)
You can boot the recovery console and from a command prompt issue the
command;
fixboot
to replace the bootsector. To start the Recovery Console, start the computer
from the Windows 2000 Setup CD or the Windows 2000 Setup floppy disks. If
you do not have Setup floppy disks and your computer cannot start from the
Windows 2000 Setup CD, use another Windows 2000-based computer to create the
Setup floppy disks. Press ENTER at the "Setup Notification" screen. Press R
to repair a Windows 2000 installation, and then press C to use the Recovery
Console. The Recovery Console then prompts you for the administrator
password. If you do not have the correct password, Recovery Console does
not allow access to the computer. If an incorrect password is entered three
times, the Recovery Console quits and restarts the computer. Once the
password has been validated, you have full access to the Recovery Console,
but limited access to the hard disk. You can only access the following
folders on your computer: %systemroot% and %windir%
Cross-post when necessary, but never multi-post. Cross-posting is when you
include two or more groups in the "Newsgroups:" section. In this scenario
the message and all responses are seen in all groups that the message was
cross-posted to. In other words any replies will automatically propagate to
the other newsgroup posts.
Multi-posting is when you post the same message to two or more groups
individually. In this scenario the message is seen in the groups it is
posted to, but the responses are only seen attached to the message (unless
you cross-post the reply) in which the response was made. So those that
frequent these groups then need to deal with or re-read the posts. It may
seem like a small thing to keep track of. But some of us actively traverse
50 or more groups. The poster also then must search out all of the posts to
see if there was a response.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| 8/4/04 by mistake)
| boot posting.
| (ASUS P4PE mb)
| Thanks
| Ken K
Sorry about that. I will abandon this thread and only post on
m.p.win2000.general. If anyone has any advice, please see that thread
under my name.
Here is my followup post there:
1, apologies for the multiple posts. I am not sure which forum received
more attention. I am also not sure how I can cross-post with Netscape
7.1---any ideas how to do it?
2, I had tried using fixboot yesterday but to no avail. I repeated
again today, but no luck. I can still boot only with the floppy in
place. Is there a BIOS setting that might have been tweaked? On POST,
I can see that the hdd is identified correctly as the primary. Somehow
I am wondering if the c: drive is just not being seen by the computer
until directed there by the floppy files...
3. I had planned on an upgrade to WinXP early next week or so. Any
chance that might fix the problem or should I wait until there is a fix
for this?
4. I would not mind doing a fresh install of Win2K if I could have all
of my setting preserved. If someone can tell me how to do that, I am
all ears.
Thanks
Ken K
>command;
>fixboot
