Hello people!
I have a problem with my MSI-K7T266pro2 MB.
I cannot change FSB freq. in bios because system monitoring column freezes when i try to enter inside. all other bios columns work just fine.
I have athlon1800xp and it should run on 133mhz and now it is 100mhz FSB
i have 512 kingmaxsuper ram(pc3200-400mhz).
it was working ok(FSB in bios at 133) until recently my powersupply burned my old ram.
Now When i changed the ram and power supply i cannot enter Monitoring options in bios(There is FSB change option). and MB is working at default 100mhz FSB.
There is no 100/133 jumper on this board, changing of freq is made in bios!
I tried to use batery jumper(to make default settings) but it doesnt help.
Does ne1 know can i fix this problem? because i think if something got burned in mb it wouldnt work at all, would it?
