Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Cooling problem on x1900xt
Forum Graphic & Displays : Graphics Cards - Cooling problem on x1900xt
So, I've had this problem for some time now but I've just been reluctant to address it.
Back in September ('06), I bought 2 new coolers: a mini-typhoon for my cpu, and a zalman vf700 for my vpu. I was going to buy the vf900 but Fry's was all out. I bring the stuff home and go to install them, but I realize that only one of them came with a VERY small tube of cheap thermal paste. Well, I, not knowing how much to put on, decided to just make it work and stretch the paste to both surfaces (cpu and vpu). Things seemed to work and I was pleased with the decrease in sound and heat (even though I hadn't ever done a heat test on either previous to the switch).
There was, however, one direct, noticable change: I could no longer overclock my graphics card. If I increased the settings the slightest bit, it would get extremely hot and eventually become unstable (within 20 minutes). So, since then, I've just left all the settings the way they were because I like my computer stable more than I like it uberpowerful (though I would like to have both if possible).
Just the other day, I was looking through Ati tray tools and noticed that my card was actually underclocked (for 3d mode I mean). Naturally, I thought nothing of it and tried to push it up to at least stock numbers. Dead. I have to restart my computer because ATI vpu recover doesn't get it back. I try again. Same results. This really sucks because I feel like I paid for half my real card (especially since I went out and bought a new vpu cooler in the hopes that I would be able to overclock it some more!) Right now, my vpu runs around 53c idle (not sure about under load because it keeps dying when I scan for artifacts).
So, I guess my questions are thus:
1) Is it just a thermal paste issue? and should I just go out and buy some Arctic Silver?
2) Is it a vpu cooler problem? (I vaguely recall reading something on a forum that said that the vf700 doesn't overclock well, but I'm not sure) Should I just order a Thermalright HR-03 and replace my old one?
3) Is it possible I did something wrong when installing it? It was my first time replacing a stock cooler and it's possible there was something I should have known about before but didn't.
4) Could somebody post/find some pictures of how much paste you need to put on it? I know everyone says 'a thin layer' but that's more vague than government work. I need a visual image to tell me what I'm doing.
Thanks :D
edit: I just finished running scan artifacts for 10 minutes and it topped out at 79c. I suppose that's not that bad, but this is at stock (500:594) :(
Sponsored Links
1. Get better thermal paste.
2. Clean off old thermal paste.
3. This time only put a PEA SIZED amount on the GPU.
4. Spread it until it is paper thin and covering the whole serface.
5. Re-apply cooler.
Edit: You might have put to much or too little thermal paste, causing the GPU to overheat and throttle-down.
Reply to terror112
Thanks for the info. I'll try that tomorrow (I can't do it today for lack of time). Also, I've read in a couple places that people would do a burn-in of sorts when they put on new thermal paste. Does that help it or something? and if so, should I just run 'scan for artifacts' for like an hour or so? or how should I do that?
Reply to link064
Well first of all, It takes time for the thermal paste to react. your temps should be high for a few days then it will go down. Just make sure u have good contact with the Cooler and GPU.
Reply to terror112
Also, I was wondering if my temps are high (53-79c)? That seems high to me, especially for having it on the stock clock constantly, but I could be wrong.
Reply to link064
The big guy at artic told me not to use artic silver on video card ram - he said something about it can conduct high requency radio waves - i think - it was almost a year ago.
so use the ceramic paste on the ram and silver on the gpu
Reply to dragonsprayer
Oh, well, my ram heatsinks didn't need any thermal paste. They were just stick-ons. The instructions just had me peel off some paper and stick the heatsinks to the memory. But thanks for the information :)
Reply to link064
Update:
Okay, so, if you say that it's supposed to be worse for the first couple days, then this is good. I bought some AS5 and reapplied some thermal grease and it's currently idling at the same temps (low 50s). It's a good thing I had noticed this because when I took off the heatsinks I noticed that it looked like there almost wasn't anything there. Apparently, I had barely applied any grease before. Hopefully (fingers crossed), the temps will drop over the next couple days...
Reply to link064
Quote :
5. Re-apply cooler.
FYI, and AFAIK, it's not PEA sized, it's "grain of rice" sized. Here's their instructions for Intel processors; they don't have any for GPU's
Arctic Silver link
Clint
Reply to CNeufeld
I wouldnt wory about those temps. When i got my x1950xt (similar, not the same) my card would run 70 idle at 90 at load. Those ati cores can take a beating, up to 100 or somethin. After i messed with the fan controlls 681/999 at 54idle-70load(stock cooling). I think you have nothing to be scared of. Also i heard that the x19xx coolers were pretty cool(but loud).
Reply to tbiggums
Okay, yet another update:
So, I got the stuff and it seems to have worked pretty well. I finally was able to OC my card and for it to be stable. However, I have only been able to OC it to what the stock OC clock is (625/725) without it becoming unbearably hot. I have ATT set it as the default clock speed (because for some reason it crashes every time I start a game if I have it do automatic 2d/3d switching). It now idles at about 55C and gets to the low 90s under full load (like Oblivion)! Ouch. If I OC it any further, it easily breaks 100C! Is that normal? For those of you with x1900xt's, do you OC, what kind of temps do you get with your coolers and what coolers do you have? I feel like I might just need a new cooler because mine is just not working enough.
Reply to link064
1. Thermal paste is SUPPOSED to be spread as thinly as possible, but evenly.
2. When I tried the VF900 I found it didn't really cool any better than the stock cooler, it was just quieter. The KuFormula VF-1 Plus and Thermalright HR-03 did a really good job though.
Reply to Cleeve
Thanks for the info. I think I may end up just replacing the vf700 with the HR-03. Sure, there's $50 going to a new cooler, but it'll help more than anything else I've tried. I don't really see a point to buying an aftermarket cooler if it isn't at least as effective as the stock cooler. At least then I will be able to put this whole thing to rest.
Reply to link064
There are 1148 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
