What is the difference between these WXGA+ and SXGA+?
SXGA+ is for resolutions up to 1400 x 1050.
WXGA+ is for resolutions up to 1336 x 768.
Do you really need the speakers in the monitor? Please tell me you're not going to use them 1.5W cannons for gaming! Anyway, this one is the same as the VA1930wm but without the speakers and for $50 less (from Newegg) and with a $40 rebate which would probably put it around what you might pay with your discount anyway. If I had to have some speakers in my monitor, I would go with the VA1930wm for the higher resolution and the slightly higher brightness.
