Hello
i recently decided to buy a new system, because my old one doesn't look good with supreme commander
my idea was to get a decent system (like a E6600) and if i need additional calculating power in about a year or two i still can overclock it ( for example if the warranty voided anyway )
is it a good idea? or should i stick to one way... either a nice system without OC or build a system with E6300 or E4300 completly relying on OC from the beginning?
here is what i thought of getting for now:
mobo: MSI P965 Platinum, S. 775 Intel P965, ATX, PCI-Express 118,07 €
CPU: Intel Core 2 Duo E6600 Box 4096Kb, LGA775, 64bit, Conroe 284,99 €
Cooler: Zalman CNPS9500 LED Sockel 478/775/754/939/940 37,96 €
RAM: 2048MB DDR2 Corsair TwinX CL 4, PC6400/800 306,80 €
Graphics: EVGA e-Geforce 8800GTS Superclocked, 640MB, PCI-Express 391,06 €
PSU: ATX-Netzt.BE Quiet! Straight Power 550 Watt / BQT E5 77,31 €
i am sorry that the prices are in euro, multiply them by 1,3 to get $, but probably the prices are not compareable anyway in europe and US
so i have a few questions left:
1. concerning the mainboard i thought of a Gigabyte DS-3 or DQ6, because they seem to have a good OC reputation, but the MSI has good reviews, too. What do you think?
2. the Corsair Ram is quite expensive compared to other DDR2 800Mhz RAM... there are modules for half the price and less... a friend told me to take this one, because it is reliable when increasing the FSB for OC. Is it worth it or am i able to go this way with cheaper RAM?
3. concerning the PSU... i thought 550 Watt would be more than enough for me... i am not going to use any SLI nor do i have many harddrives or other demanding stuff beside the one GF 8800... BUT for OC i was told that i need a reliable and constant powersupply and so i was choosing this one, but i don't really now if it's good... maybe the OCZ GameXStream 520 Watt is a good choice, too?
i really don't know if i should build an OC system from the beginning or stick with something probably more expensive but more reliable, too... the way in between may not be a good choice, i guess.
Thanks for your time and thoughts in advance
