Tom's Hardware > Forum > Windows 2000/NT > Windows 2000/NT General Discussion > RIS Problems with Compaq Evo (Ultra Slimline)
Forum Windows 2000/NT : Windows 2000/NT General Discussion - RIS Problems with Compaq Evo (Ultra Slimline)
Archived from groups: microsoft.public.win2000.setup (More info?)
Hi,
I've been testing RIS for the past 2 months and it all seems to work fine,
with most of our hardware. However I've just tried to install windows 2000
to a Compaq Evo D51U (ultra slimline desktop) and received the following
blue screen error "Stop 0x00000BB - initialisation failure attempting to
boot from network".
The network card is an intel pro 100, which normally works fine with RIS.
These Evo's have been a problem in the past. For some reason you can't build
a hard disk then clone the disk for another evo, as it just fails with an
inaccessible boot disk error, each one has to be installed manually, which
takes a lot of time. I was hoping RIS would solve this problem. However it
looks like they are still going to cause problems.
I've searched MS site, however can't find anything on this problem. Can
anyone help?
Ben
IT Professional, MCP 70-210
"On my way to becoming fully certifiable!"
Sponsored Links
You need to update the RIS Server with new drivers...
See this article
How to add nic drivers to RIS Images
http://www.wug-nordic.net/articles/ris-add-nic.htm
regards
Johan Arwidmark
Windows User Group - Nordic
On Wed, 18 Aug 2004 15:14:03 +0100, "Ben"
<bjblackmore@nospam.hotmail.com> wrote:
>Hi,
>boot from network".
>anyone help?
Reply to Anonymous
Hi,
I have added the drivers for this NIC to the image, and it does boot of the
NIC and run setup, however it is after the initial setup screen, that I get
a blue screen of death with the error "Stop 0x00000BB - initialisation
failure attempting to boot from network", I do not get the error saying
"image does not contain drivers for your network adapter" which would
indicate missing drivers.
Ben
"Johan Arwidmark" <johan.please_respond_to_forum.arwidmark@lutteman.se>
wrote in message news:r038i0ti7vbgfn48foldv7trvfmb4fidsj@4ax.com...
> See this article
> regards
> Johan Arwidmark
> >Hi,
fine,
2000
> >boot from network".
build
which
it
> >anyone help?
Reply to Ben
We are using that exact model at a custome site, and for that
particular OEM driver you'll either need to wither change the
[SourceDisksFiles] paths in the .INF files or actually copying in the
nic driver structure to the $oem$ structure...
If cossing the file structure scenario the structure should look like
this:
$oem$\drivers\nic\Windows\Drivers\IA32
Note: the INF files should be in $oem$\drivers\nic
If you choose to modify the .INF files the drivers should be place
directly in $oem$\drivers\nic
dont forget to add following lines to ristndrd.si
[Unattended]
OemPreinstall = yes
Oempnpdriverspath = \Drivers\nic\
DriverSigningPolicy = ignore
You can also try using the latest drivers from Intel for the Intel VE
NIC (works with the VM cards)
regards
Johan Arwidmark
On Mon, 23 Aug 2004 10:58:24 +0100, "Ben"
>Hi,
>Ben
>> See this article
>> regards
>> Johan Arwidmark
>> >Hi,
>fine,
>2000
>> >boot from network".
>build
>which
>it
>> >anyone help?
Reply to Anonymous
There are 1291 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
