So I recently had a motherboard go bad so I ordered a duplicate Asus A7N8X-E motherboard. I bought a new WD raptor drive for a clean install and I have a 250 gig IDE drive that has Windows Vista on it that I can no longer use..
I did a clean install on the Raptor drive of XP, had to use the SATA controller drivers on a floppy to get it to work. Then i plugged in my IDE drive and changed my bios so that I would boot the SCSI(sata) drive first(had problems unless i did that, it tried to boot the IDE). Everything worked perfect once i had the right settings. I could see the IDE drive in windows, manipulate it. So i thought since everything was running smoothly i could connect my DVD-R drive back up. So i switched a few things around and connected a DVD drive, DVD-R drive and my IDE HD on my ide channels(I think I may have switched the channel on the HD, from master to primary, but i didn't think that mattered much??). Sorry this is long winded i just want u to know my process.
Well now half if not 90 percent of the cable configurations i try, windows will load the SATA drive, but right as the blue windows welcome screen is supposed to come up it turns itself off kinda like a tv screen turning off. No windows boots up cause i dont hear the welcome windows sound. So is that the graphics card? Or is the old IDE HD giving me problems? I suspected it was the IDE, cause i tried to copy some files (mp3, documents etc,) when i had a succesful boot up with both the raptor and IDE, and it completely locked up my system about half way through the copy, and made a clicking sound I think i just need to format it completely and get rid of old vista and everything, but I NEED some of the files on my IDE HD. So i need help figuring out why the IDE HD could be causing my whole windows to not load up, it shoudln't be a bad drive as its fairly new(less then a year old). I just got the Raptor drive as an added speed bonus. The weird thing is, if i unplug the IDE hd completely the raptor drive now wont boot up the fresh Windows XP install i just did, its like its needing that IDE drive now, it sucks.
Any suggestions on programs that can copy HD folders(specficall IDE to SATA not in Windows) easily would be well appreciated, And does my IDE drive since it was initially setup as lets say the E, have to stay that way in the config for windows to boot back up properly again? Alot of questions I know...thanks for any help!
im getting really tired, so i may head to bed soon, but ill try my best to answer...
1) you may still be able to use vista on the pata hdd, if you do a repair on it booting from the dvd
2) you said everything was working fine even when you connected your pata hdd... up until you also connected both of your dvd drives too, and you also said the jumper configurations may be wrong... ...so you may possibly have some jumper conflicts... disconnect both dvd drives and see if you still have problems using windows, if no problems, then reconfigure the jumpers on the drives, cable select works as well for all 3 pata drives
3) a clicking hdd indicates it may be failing, system lock up during file copying between it and another drive indicates it may be failing... you should run check disk to scan the drive for errors
4) if windows is dependant on a secondary hdd being connected so it can boot, run a windows repair on the raptor, without the pata hdd being connected... after the repair is done, and everything is fuctioning again in windows, reconnect only the pata hdd, to a seperate ide channel than either dvd drive... and boot into windows, it should work
5) drive lettering doesnt matter (windows by default is always C: ), windows will reassign drive letters according to which devices are connected at a given time
