installation problem
Last response: in Windows 2000/NT
September 11, 2004 7:02:51 PM
Archived from groups: microsoft.public.win2000.setup (More info?)
My hardrive crashed and I'm trying to re-install w2000
but it never gets past the screen that says it is
analyzing the computer configuration. I let it go for an
hour and then turned the computer off.
More about : installation problem
Anonymous
September 11, 2004 10:56:31 PM
To do a clean install, either boot the Windows 2000 install CD-Rom or setup
disks. The set of four install disks can be created from your Windows 2000
CD-Rom; change to the \bootdisk directory on the CD-Rom and execute
makeboot.exe (from dos) or makebt32.exe (from 32 bit) and follow the
prompts.
When you get to the point, delete the existing NTFS and or other partitions
found. After you delete the partition(s) abort the install, then again
restart the pc booting the CD-Rom or setup disks to avoid unexpected drive
letter assignments with your new install.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
