Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Future Graphics card power requirements aka R600
Forum Graphic & Displays : Graphics Cards - Future Graphics card power requirements aka R600
Hi everyone!
I am quite concerned withe the dramatic size and power increase in the graphics cards these past years. A few months ago, I purchased a OCZ GameXtreme 700W psu thinking I would be somewhat futureproof. I've waited through the 8800s for the r600s and now I am confused whether my psu will be able to handle a r600.
I hear that there's a 6pin and a 8 pin power connectors on the r600. I have 2 6pins. Does that mean I need to plug both into the 8 pin with an adaptor and use a molex adapter for the 6pin or do i plug one into the 6pin and the other into the 8pin or do i do that and use an additional adaptor to combine a 6pin and a molex for the 8pin.
And when will there be 16pins?
Sorry for the confusing paragraph.
Thanks for reading! :D
Sponsored Links
The retail version of the R600 is coming with 2 x 6pin, only the OEM part has the 2 x 8pin, you will be OK for now.
Reply to jamesgoddard
The GameXtreme you have will most likely handle R600.
If not, you'll need a nuclear reactor instead. :( :wink:
Reply to prozac26
The latest news/rumors have the r600 running 240-300w at full load.
As for the pins, last I heard was the retail would come with 1 6 pin + 1 8 pin connector. The card could be run safely using 2 6pins, but in doing so prevents you from using ati overdrive utilities. Only people using the 6+ 8 pin setup can use overdrive.
Again these are only rumors even if they come from reliable sites. the cards been pushed back so many times, it's hard to tell what info is correct, what is wrong and what might have been correct but has since been changed.
I don't think anyone will know for sure till the cards show up in peoples hands.
Reply to grifter33
- 0 +
Your psu is more than adequit for running the 8800 or R600 series.If 8pin connectors are needed then you'll probably get and adapter or two with the card.Goodluck.
Dahak
AMD X2-4400+@2.6 S-939
EVGA NF4 SLI MB
2X EVGA 7950GT KO IN SLI
2X 512MB CRUCIAL BALLISTIX DDR500
WD300GIG HD
ACER 22IN WIDESCREEN LCD 1600X1200
THERMALTAKE TOUGHPOWER 850WATT PSU
COOLERMASTER MINI R120
3DMARK05 13,442
Reply to Dahak
Thank you all. I think it has been clear that my PSU is enough for the job. Again, THANK YOU!!!
Reply to johnaintdoe
There are 1023 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
