i had two incidents. 1st is i had two monitors, one is newly bought. i wanted to try the new one so i plugged all the cable. before plugging in the vga cable to the pc, i took out my older monitor's dvi cable but the cable touched the back of the casing. i tried to switch on the pc but i won't run. second incident is the LAN cable. i took out to try on a laptop. when came to fixing it back to the pc, it auto shutdown. i'm able to on my pc after half an hour of plugging out the power cable in both incidents. my guess is the power supply fault but i want to get confirmation from fellow forum posters. thanks
