Archived from groups: microsoft.public.win2000.setup,microsoft.public.win2000.setup_deployment,microsoft.public.win2000.setup_upgrade (More info?)
Hello,
I have the following problem when trying to format my laptop. I have
Windows 2000 Professional, which includes 4 floppies and a Cd. After I
am asked to insert floppy #2 (while booting computer), and error
message appears saying the following:
File \halacpi.dll could not be loaded.
The error code is 7
Setup cannot continue. press any key to exit.
I have tried numerous things to bypass this problem, including trying
to boot from the CD-ROM (after having changed my booting order in the
BIOS). I have also started Windows and have tried to go into the Cd’s
"English" folder (the only folder on the Cd) but the computer
replies "Do you want to format the CD-ROM drive"!!!???. I have put
the Cd in another computer to verify whether or not is working
properly and I was able to access the "English" folder as well as
activate the setup directly from the Cd; thus, the Cd should be fine.
The one thing I did not try was to boot that other computer with the
floppies; I don’t want to format that other computer now. Please let
me know what can I do to fix this error and be able to do a full
format of my harddrive. By the way, I have used these floppies and Cd
before to format that same laptop and the other computer I mentioned
with no problems (about three years ago).
Thank you,
Jorge
PS: My laptop is a Pentium 800Mhz with 256MB and 20GB of HD.
Two things come to mind; You might try clearing (resetting) cmos to factory
default. You may have a defective RAM module.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
"eurojourney" wrote:
| Hello,
| The error code is 7
| BIOS). I have also started Windows and have tried to go into the Cd's
| floppies; I don't want to format that other computer now. Please let
| Thank you,
| Jorge
| http://www.WindowsForumz.com/ This article was posted by author's request
| Articles individually checked for conformance to usenet standards
| Topic URL:
http://www.WindowsForumz.com/Setup [...] 89350.html | Visit Topic URL to contact author (reg. req'd). Report abuse:
http://www.WindowsForumz.com/eform.php?p=555669
Archived from groups: microsoft.public.win2000.setup (More info?)
Could be that the second disk is faulty. If you go onto
the CDROM and find the "BOOTDISK\" directory and at the
DOS prompt type "MAKEBOOT a:" to recreate the boot
floppies.
You'll need 4 blank floppies for this, and probably need
to do it from another PC.
Hope this helps
>-----Original Message-----
>Regards,
newsgroup.
>| Hello,
laptop. I have
and a Cd. After I
and error
>| The error code is 7
including trying
into the Cd's
computer
I have put
working
as well as
should be fine.
computer with the
now. Please let
do a full
floppies and Cd
>| Thank you,
>| Jorge
of HD.
by author's request
standards
>| Topic URL:
>http://www.WindowsForumz.com/Setup---Deploy---Upgrade-
Problem-Reinstalling-Win-2K-Pro-Error-Code-halacpi.dll-
ftopict189350.html
abuse:
Archived from groups: microsoft.public.win2000.setup_upgrade (More info?)
>Hello,
laptop. I have
a Cd. After I
and error
>The error code is 7
including trying
order in the
into the Cd's
computer
have put
working
well as
should be fine.
computer with the
Please let
a full
floppies and Cd
I mentioned
>Thank you,
>Jorge
HD.
author's request
standards
>Topic URL: http://www.WindowsForumz.com/Setup---Deploy--- Upgrade-Problem-Reinstalling-Win-2K-Pro-Error-Code-
halacpi.dll-ftopict189350.html
abuse: http://www.WindowsForumz.com/eform.php?p=555669 >.
Error code 7 means:
The storage control blocks were destroyed.
Seems like you may have a RAM problem, as Dave Patrick
suggested.
> >Hello,
> laptop. I have
> a Cd. After I
> and error
> >File halacpi.dll could not be loaded.
> >The error code is 7
> including trying
> order in the
> into the Cd's
> computer
> have put
> working
> well as
> should be fine.
> computer with the
> Please let
> a full
> floppies and Cd
> I mentioned
> >Thank you,
> >Jorge
> HD.
> author's request
> standards
> >Topic URL: http://www.WindowsForumz.com/Setup---Deploy--- > Upgrade-Problem-Reinstalling-Win-2K-Pro-Error-Code-
> abuse: http://www.WindowsForumz.com/eform.php?p=555669 > >.
> Error code 7 means:
> suggested.
Can these problems be associated with a virus? Since I had the CDROM
for Windows Millenium (which I really don’t like) I tried to install
it. It seems to work so far. I will try to reinstall Windows 2000 now
and see if I can get it to work. I am concern about the potential RAM
problem. If that is the problem in the end, will buying new RAM solve
the problem or am I facing an unrepairable condition with my Laptop?
Let me know...
