First off, is a cheap (~$30) sound card any better than onboard audio?
Next off, will I even notice the difference with a sub-$30 "sound system" (quoted because it most likely can barely be called a sound system...)?
Sound card-wise I was looking at the Creative Sound Blaster Audigy SE SB0570LPVP 5.1 Channels PCI Interface Low-Profile Sound Card.
I've been looking at the Cyber Acoustics CA3001WB 14 watts 2.1 Speaker & the DCT Factory OG-550 25 Watts 5.1 Speaker.
Even though I'm going on the extra cheap sound-wise, will I get a significant difference to going up from 2.0 to 2.1/5.1 and onboard to a low end sound card?
Are there any other speakers I should look for, on the cheap?
Thanks!
Thanks!
