Archived from groups: alt.tv.tech.hdtv (More info?)
Last year / earlier this year, I went through 4 Explorer 8000 boxes
due to freezing, glitches, and random reboots. Finally, a tech came
by and installed a Motorola BDA-S4 Broadband drop amp.
That seemed to do the trick and my box started performing normally
until last week.
Last week, Time Warner in Raleigh, NC finally began rolling out their
Explorer 8000HD High Definition DVR boxes. I had been using their
regular HD box, so I decided to trade up and try out the HD DVR but
keep my existing Explorer 8000 due to the limited space on the
Explorer 8000HD.
Some weird things happened when first hooking up the 8000HD. I hooked
up the 8000HD and it worked fine. However, when I switched over to my
existing Explorer 8000 (non HD DVR), all my saved show, scheduled
recordings, and series manager and been deleted. It was as though it
went back to factory default. I was stunned to see that hooking up
the Explorer 8000HD would do this to my regular Explorer 8000. So, I
rebooted my Explorer 8000 and nothing. Still the same. I rebooted
once more and voila! All the saved shows, scheduled recordings, and
series manager shows came back exactly as they were before I installed
the Explorer 8000HD. Both boxes are coming off separate lines coming
out of the Motorola Broadband amp (the amp has 4 jacks coming out of
it).
What is happening now is that the Explorer 8000 is now doing what is
was earlier in the year as described below. It freezes, glitches, and
randomly reboots after locking up. The Explorer 8000HD seems to be
doing fine with the exception of a random video artifact here and
there.
The problem I am having is that no matter what channel I record on or
the time of day, about 60-70% of the programs I record don't play
back correctly, if at all. During the playback, there is pixelation,
screen freezes, skipping of program recording (10 seconds to minutes
at the time), complete freeze of playback with no recovery, or the box
reboots by itself.
Anyone having this problem, solved this problem, or hooked up a SA
Explorer 8000HD and Explorer 8000 at the same time?
Just wanted to know if I was the only person this is happening to. I
would suspect not!
Thanks in advance. Any help would be greatly appreciated.
