Archived from groups: microsoft.public.win2000.setup (More info?)
Often, when I bring up the add/remove programs control panel, I get the
following error:
"an unexpected error occurred
Class not registered
res://appwiz.cpl/listbox.htc
Line:225"
It then informs me that no programs are installed on my computer. I was
thinking that this might have something to do with the fact that windows is
not installed on the C: drive on my computer. Instead, due to my partion
set-up, windows is installed on my D: drive. Is there any way I can fix this?
I need to be able to uninstall some software...
Thanks,
Sanborne
Sponsored Links
From the "Run" box try;
regsvr32 %windir%\system32\appwiz.cpl
regsvr32 %windir%\system32\webvw.dll
to rebuild several *.htt files
If unsuccessful try
sfc /purgecache
sfc /scannow
Or try the regedits described in;
Add/Remove Programs Tool Displays Installed Programs Incorrectly
http://support.microsoft.com/default.aspx?kbid=266668
If the problem persists, you'll likely need to perform an in-place upgrade.
How to Perform an In-Place Upgrade of Windows 2000
http://support.microsoft.com/default.aspx?kbid=292175
What an In-Place Windows 2000 Upgrade Changes and What It Does Not Change
http://support.microsoft.com/default.aspx?kbid=306952
Be sure to apply these to your repair install before connecting to any
network.
http://www.microsoft.com/technet/s [...] 3-043.mspx
http://www.microsoft.com/technet/s [...] 3-049.mspx
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| following error:
| Line:225"
is
this?
| Thanks,
| Sanborne
Reply to Anonymous
Tom's Hardware > Forum > Windows 2000/NT > Windows 2000/NT General Discussion > Add/Remove programs problem
There are 421 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
