Archived from groups: microsoft.public.win2000.setup (More info?)
Win2000 Pro hanged because 2000>\system32\ntoskrnl.exe was missing or
coruppted.
I made the 4 floppies from the original Win200 CD, booted, inserted original
CD. It asked me for an Emergency Repair Disk which I don't have. So I tried
reinstalling Win2000 Pro. Now I'm stuck: hard drive is not recognized by the
operating system.
I tried a diagnostic tool (PowerMax), Power connection,Interface
cable,Master/slave Jumpers all passed. All other tests FAIL.
Please help.... pretty desparate.
"havingtroble" <havingtroble@discussions.microsoft.com> wrote in message
news0245BB8-93AC-4A78-9740-78B323C6D3D1@microsoft.com...
> coruppted.
original
tried
the
> operating system.
Here are a few tools that can be used to restore lost partitions:
You didn't mention the drive controller (possibly SCSI, or ultra DMA, or
ATA100, or raid, or serial ATA), but you may need to boot the Windows 2000
setup disks or CD-Rom and *F6* very early and very important (at setup is
inspecting your system) in the setup to prevent drive controller detection,
and select S to specify additional drivers. Then later you'll be prompted to
insert the manufacturer supplied Windows 2000 driver for your drive's
controller in drive "A"
If you wait and then S to specify additional drivers, then it may be too
late as Windows 2000 Setup at this point may have already assigned the
resources your drive's controller is wanting to use.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| coruppted.
original
tried
the
| operating system.
Tkx so much for your help, but no luck. I tried BootMaster Plus from
http://bootmaster.filerecovery.biz/ but dsnt do anything since it cant "see"
the hard drive. Pls tell me if the's anything I can do so HD can be
recognized so I can do a fresh installation, don't care if I loose all the
data I have on the hard disck. Tkx again
> > coruppted.
> original
> tried
> the
> > operating system.
> http://www.restorer2000.com/r2k.htm (to restore NTFS partitions - seems to
> work well)
> http://www.hddrecovery.com.au > http://bootmaster.filerecovery.biz (has NTFS undelete tools too)
> http://www.runtime.org/ (GetDataBack)
> www.acronis.com (RecoveryExpert)
Tkx for your help Dave, but no luck. I booted from the first floppy,
(pressed F6 at the point it said on the bottom of the screen) but it went
ahead asking me for the other 3 floppies. After that it asked for my Win2000
CD, and then I got a message saying no HD was installed and had to abort
instalation. The only thing I'm able to do is enter setup with "DEL", do I
have to change anything in the BIOS? Pls tell me if there's anyway I can do a
fresh install even if I loose all I have on the HD. Tkx again.
havingtroble
> Regards,
> http://www.microsoft.com/protect >
> | coruppted.
> original
> tried
> the
> | operating system.
It seems your Subject line is incorrect: It's not that the operating
system fails to recognise the hard disk but rather that your PC
fails to recognise it. This means that it's a hardware issue, and
should really be discussed in a hardware group.
Anyway, here is what I would do in your situation:
- Get an old disk (e.g. borrow one from your friendly computer
dealer) and install it as a primary master. If the system cannot
recognise it then you probably have a problem with your
BIOS/motherboard/ribbon cable/power supply.
- Install your disk as a slave disk in some other PC. If that
PC cannot recognise it then you probably have a dead disk.
news:AD740B02-E3F4-44E8-9409-257B9D8F8F8F@microsoft.com...
"see"
> > > coruppted.
> > original
> > tried
by
> > the
> > > operating system.
to
> > work well)
> > http://www.hddrecovery.com.au > > http://bootmaster.filerecovery.biz (has NTFS undelete tools too)
What drive controller? Is the controller and drive connected to it
recognized at POST?
Regards,
Win2000
do a
| havingtroble
Try getting a Windows PE and boot the system using a CD-ROM, use the
"DISKPART" utility to check/activate/re-create your disk partitions.
Lawrence Tse
MCT, MCSE:Messaging, MCSA:Messaging, MCDBA, MCSD, MCSE+Internet, MCP+Site
Building
> coruppted.
original
tried
the
> operating system.
Thanks for your time and patience. All I can tell you is:
CMOS setup, IDE Primary Master gives me:
Maxtor Proxima Firmware YAH814YZ (can't find this on Maxtor site)
Capacity 20498
Cylinder 39715
Head 16
Precomp 0
Loading Zone 39714
Sector 63
I read on a data recovery site that if you see "Proxima" on BIOS screen it
means the drive can't be recognized by BIOS. True?
Do I have to open the computer to see the drive?
Tkx again.
> recognized at POST?
> Regards,
> Win2000
> do a
> | havingtroble
tkx, will try and let you know
> Lawrence Tse
> Building
> > coruppted.
> original
> tried
> the
> > operating system.
What happens when you boot? The pc goes through POST. Is the controller and
drive connected to it recognized?
Regards,
| Capacity 20498
| Cylinder 39715
| Head 16
| Precomp 0
| Loading Zone 39714
| Sector 63
| Tkx again.
Hi,
Here's what I get on the black screen when I boot:
Phoenix-Award Bios v6.00PG .....
L7VMM2 3.0 2/21/2033
Main processor: AMD Athlon 100 MHZ
Memory testing 262144K OK
Primary Master: Maxtor Proxima YAH814YZ
Primary slave: NONE
Sec. Master: Creative CD
Sec, Slave: Memorex CDRW/DVD
PRIMARY MASTER HARD DISK FAIL
F1 to continue, DEL to enter setup
Does that answer your question? Thanks again and regards
> Regards,
> | Capacity 20498
> | Cylinder 39715
> | Head 16
> | Precomp 0
> | Loading Zone 39714
> | Sector 63
> | Tkx again.
Hi, forgot to mention the drive is a serial ATA.
Thanks.
> Regards,
> | Capacity 20498
> | Cylinder 39715
> | Head 16
> | Precomp 0
> | Loading Zone 39714
> | Sector 63
> | Tkx again.
is the bios set to boot from sata ?
Geoff
wrote in message
news:FED0A519-0713-4F8C-800E-3DB4489B0B26@microsoft.com...
> Thanks.
the controller and
> > Regards,
newsgroup.
> > http://www.microsoft.com/protect > >
is:
Maxtor site)
> > | Capacity 20498
> > | Cylinder 39715
> > | Head 16
> > | Precomp 0
> > | Loading Zone 39714
> > | Sector 63
> > | Tkx again.
Yes it does. The drive has failed and or is improperly configured in cmos
setup.
Regards,
| Hi,
| Primary slave: NONE
throw away drive? where can I look up right cmos config ?
tkx
> setup.
> Regards,
> | Hi,
> | Primary slave: NONE
Hi,
what's sata pls ?
> Geoff
> wrote in message
> > Thanks.
> the controller and
> > > Regards,
> newsgroup.
> > > http://www.microsoft.com/protect > > >
> is:
> Maxtor site)
> > > | Capacity 20498
> > > | Cylinder 39715
> > > | Head 16
> > > | Precomp 0
> > > | Loading Zone 39714
> > > | Sector 63
> > > | Tkx again.
Check your mobo manual. Generally setting to auto detect should work.
Regards,
| tkx
what you said your drive was ?
serial ATA = SATA
wrote in message
news:001DC493-B594-4A4B-8C41-87EC36487B85@microsoft.com...
> Hi,
> what's sata pls ?
> > Geoff
> > wrote in message
> > > Thanks.
POST. Is
> > the controller and
> > > > Regards,
> > newsgroup.
> > > > http://www.microsoft.com/protect > > > >
you
> > is:
on
> > Maxtor site)
> > > > | Capacity 20498
> > > > | Cylinder 39715
> > > > | Head 16
> > > > | Precomp 0
> > > > | Loading Zone 39714
> > > > | Sector 63
> > > > | Tkx again.
