Bus speed question... or is it?
Bare with me here folks…. I have a question about system bus speed and now different components contribute to the overall ‘speed’ of a system. I’m a novice so any advice/explanations received would be much appreciated. I have a system with a Celeron D 346 that has a FSB of 533 Mhz and DDR2 RAM also running at 533Mhz. The board bus speed is advertised in the manual as 800 Mhz but the system reports running at 533Mhz. I take it this is because the ‘overall’ bus speed is determined by all components throttling back to the lowest speed? Right/wrong? I’m toying with the idea of replacing the Celeron with an 800 Mhz Pentium 4 631 with FSB of 800 Mhz. I take it that the Pentium would also throttle back and run at 533 Mhz because, according to the board manual it can only accept 400 or 533 Mhz DDR2 SDRAM? Yes/no? If so would I notice much of a difference with the Pentium (with Hyper-Threading and 2MB of L2 cache) over the Celeron (only 256KB L2 cache). As you can see this query is from a novice so any pearls of wisdom you would like to share with me would be much appreciated. Thanks.
4 answers Last reply
More about speed question
  1. The CPU is a 533. So you are limited by that, even though the MB will support DDR2 800 memory. Even if you use DDR2 800 memory with the celeron, it will down clock it to 533.
    Quote:
    Model
    Brand Intel
    Processors Type Desktop
    Series Celeron D
    Model BX80547RE3066CN
    CPU Socket Type
    CPU Socket Type LGA 775
    Tech Spec
    Core Prescott
    Multi-Core Single-Core
    Name Celeron D 346
    Operating Frequency 3.06GHz
    FSB 533MHz
    L1 Cache 12KB+16KB
    L2 Cache 256KB
    Manufacturing Tech 90 nm
    Vista Ready Yes
    64 bit Support Yes
    Hyper-Threading Support No
    Virtualization Technology Support No
    Multimedia Instruction MMX, SSE, SSE2, SSE3
    Voltage 1.25-1.4V
  2. Hi.... thanks for your reply. The board is a Dell 0JC474. It's a Dimension 3100. The manual states the chipset is a 915GV chipset but running the Intel Chipset ID utility it tells me it's a 915G/910GL Express chipset! The 915GV supports 800Mhz bus CPU’s and DDR2 but the 910GL doesn't. Needless to say this makes no sense to me and I'm still wondering what chipset I have!!
  3. Try Using:
    CPU-Z
    That should also help verify your chipset and more info on your system.
    What are trying to accomplish or understand exactly?
  4. Quote:
    Well your wrong
    The Mb can run at 800MHZ FSB but as your CPU is for a 533MHz FSB it will run 533
    You might want to try overclocking that Celeron as your MB can do higher FSB but as its a dell mb you prob cant...
    The ram dont have to run at the same speed as your FSB (even if its pref)
    You run the FSB/ram with a divider of 3/2 so 800FSB gives 533MHz RAM
    The FSB isnt all that determend performance but as u asumed cache playes a vital role how well a CPU perform (esp intel ones)
    So going from a Celeron 256kB cache to a pentium 2M cache will give u pretty good gains (like 20-30% in games) at the same clockspeed.
    i dont give much for HT but some programs make use of it (and some perform worse).
    Hope this helped some
CPUs Celeron Bus Speed Components
