Millenium O/S Problems
Forum Windows 2000/NT : Windows 2000/NT General Discussion - Millenium O/S Problems
Archived from groups: microsoft.public.win2000.setup (More info?)
I am running Millenium on my computer...when I start it up everything seems
to run normally.but when it gets to the desktop it goes black..the only thing
visible is the cursor..i hit ctrl-alt-del and the task manager comes up..but
I cannot see anything other than that. How can I fix this problem? WHAT is
the problem?
Help is greatly appreciated.
Sponsored Links
Try posting in a Millennium group.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
thing
up..but
| the problem?
Reply to Anonymous
Usually caused by a broken Internet Explorer but could also be pretty
park virus. Read here:
Blank desktop or illegal operations error message after you install
Internet Explorer
http://support.microsoft.com/defau [...] -us;249191
If you don't have the virus try repairing IE from the command prompt
(with your Windows ME Startup floppy disk "Minimal Boot" option), or by
switching the explorer shell as described in the previous article.
Description of the Internet Explorer Repair Tool
http://support.microsoft.com/defau [...] -us;194177
John
> the problem?
Reply to Anonymous
You're response would have been greatly appreciated had you directed me to
the right place otherwise you're just wasting time.
> Regards,
> thing
> up..but
> | the problem?
Reply to Anonymous
> me to the right place otherwise you're just wasting time.
How about searching newsgroups? m.p.windowsme.general.
Dave isn't wasting time - just trying to prevent you from doing so, by
posting in the wrong group for your question.
>> Regards,
>>> everything seems to run normally.but when it gets to the desktop it
>>> goes black..the only thing visible is the cursor..i hit
>>> ctrl-alt-del and the task manager comes up..but I cannot see
>>> anything other than that. How can I fix this problem? WHAT is the
>>> problem?
Reply to Anonymous
Might this be direct enough?
http://communities2.microsoft.com/ [...] g=en&cr=US
Regards,
"Cade Shane" <CadeShane@discussions.microsoft.com> wrote in message
news:B7787ACD-D83A-4570-9995-3B4516C2291B@microsoft.com...
Reply to Anonymous
Thank you...much appreciated.
> Regards,
Reply to Anonymous
THANKS..PROBLEM SOLVED.
> the problem?
Reply to Anonymous
Tom's Hardware > Forum > Windows 2000/NT > Windows 2000/NT General Discussion > Millenium O/S Problems
There are 460 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
