Yes No
Ads
Tom's Hardware > Forum > Home Theatre > HDTV > Problem with using Harmony Remote with Zektor switchbox
Forum Home Theatre : HDTV Problem with using Harmony Remote with Zektor switchbox
Archived from groups: alt.tv.tech.hdtv (More info?)
I have a Zektor HDS4 switchbox which is a component video switchbox.
The odd problem is I can use my remote for a JVC VCR (on cable box
mode as a cable box) and switch component inputs whether I'm standing
in front of the box or in another room (using the remote through a
Powermid Remote Extender system). It works fine both ways. Yet I
have programmed my 688 to use this switchbox when switching between
HD-TIVO and D-VHS (components 1 and 2 in) and it works fine if I'm
standing in front of the switchbox but won't work if I'm using it in
another room through the remote extender system. I have tried
changing codes, learning the codes off of the JVC remote, etc. with no
luck. I know it's not purely a Harmony issue since it semes to only
be a problem when I deal with the Remote Extender but as well I don't
know if it's that the Remote Extender somehow modifies the codes (but
only through the Harmony, not the VCR remote obviously) or what's
going on. It's a annoying issue I have had no luck with at all. Any
ideas what's causing this? I have thought about changing to another
switchbox but I like the Zektor so much and want to stay with it and
someday in the future hope to get a HDMI switchbox from them.
Reply to Anonymous
There are 1959 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 23 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
Top experts
