Looks the the more than famous Tuniq Tower 120 has bowed downed to a new champion in air cooling superiority.
The Thermalright 120 Plus with a X6800 clocked at 3.90Ghz mainted an idle temperature of 35C and a load temp of 45, besting the Tuniq Tower by 6 and 7 degrees respectively. While the Thermalright 120 Plus maybe the more expensive it is the best air cooling solution out there right now. You could also opt for the Thermalright 120 if you don't prefer the look of the tuniq which gives identical performance to the Tuniq Tower for the same price.
Simple amazing in terms of air cooling, not sure they could advance much more in the way of dissipating heat without using TEC's or Water.
Check out the amazing results HERE!
