G
Guest
Guest
Archived from groups: microsoft.public.win2000.setup (More info?)
Hi,
I'm running win2k server. Whenever I try to run a system command, such as
net use (net anything), calc, etc. the command line comes back and tells me
that it is not a known command, batch file, etc. I know that what has
happened is that it has lost its pointer, or whatever other means that it
uses, to know that when those things are typed that it should look in the
system32 folder. What I don't know is why that happened, and how to fix it.
Does anybody have any ideas?
Thanks,
John
Hi,
Thanks,
John
