Hello folks,
As the subject states i'm getting some strange readings (I was a bit tired this morning when Computronics was very kindly trying to help me) So now i'm going to make absolutely sure I give all the correct info:
Tcase = 16-18C & 40-43C
Tjunction = Core0 18C Core1 20C & Core0 43C Core1 43C
Above temps are taken using Core temp, Speedfan, Everest & Easytunes Hardware Monitor.
TAT Readings; Idle Core0 35-40C Core1 37-42C Load Core0 54-57C Core1 54-55C
Bios is reading temps Tcase 20C System 30C
Ambient = 21C
Chipset = 965P
C2D = E4300
CPU Cooler = Arctic Freezer 7 Pro
Frequency = 2997MHz
Load = TAT + Orthos
Motherboard = GA 965P DS3 Rev2
Vcore = 1.3250
As you can see these are very low and I can only think that these temp monitors are perhaps incompatable with vista; TAT is the only one that differs from the rest but perhaps the rest are incorrect and TAT is right but i've heard TAT can't read this chip correctly and has compatability issues with Vista.
This is confusing as I'd like to know my exact temps can anyone confirm successful readings with any of the above software in Vista?
Thanks!
Vic.
EDIT; The Case Air temp is lower than the room Ambient temp as you can see from my Build i have a very empty case and the airflow is great. My legs actually get cold next to the case :twisted:
If you have ever used the Antec NINE Hundred case I have mounted the HSF so it blows the air out of the case through the back 120mm Fan, the top 200mm fan is on high and the front two are on high & medium respectively.
Ambient = 21C
Chipset = 965P
C2D = E4300
Frequency = 2997MHz
Load = TAT + Orthos
Vcore = 1.3250
Thanks!
Vic.
