Archived from groups: microsoft.public.win2000.setup (More info?)
After switch on, my PC gets as far as displaying the
blue/white 2000 Pro loading screen then displays a plain
blue screen for a fraction of a second (just long enough
to see there is some dos text in the top left) before
switching off and running BIOS/mem test over again ...
and so on.
I assumed, obviously wrongly, that the recommended
Emergency Repair Disk I made when first loading 2000,
could be used to make an emergency repair.
Try a safe mode boot. (F8 key at startup)
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| and so on.
| Any help out there?
| hap
Thanks but no joy.
Selected Safe Mode. Displayed "Starting Windows ...." (DOS screen), joined
the dots then switched off again. Next time F8 didn't even operate!
Any other ideas?
"Dave Patrick" <mail@Nospam.DSPatrick.com> wrote in message
news:uk%23gOjlKFHA.3640@TK2MSFTNGP12.phx.gbl...
> Regards,
> http://www.microsoft.com/protect >
> | and so on.
> | Any help out there?
> | hap
I don't know how much good this will do, but from a parallel install, run
regedt32.exe, then from the Local Machine Hive, choose Registry|Load Hive,
then navigate to the
%windir%\system32\config
directory on the other install, and find the system file, then Open, in the
Key Name box give it some temp name, then under tempname, navigate to
HKEY_LOCAL_MACHINE\SYSTEM\Select
and look in the Reg_Dword value of "Current", this is the current
controlset, then navigate to
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet00x\Control\CrashControl
Where x = the value of "Current" (found above) and set the values as follows
"AutoReboot"=dword:00000000
"CrashDumpEnabled"=dword:00000001
"LogEvent"=dword:00000001
"Overwrite"=dword:00000001
Then navigate back up to "tempname" and choose Unload Hive, and boot your
original install, Autoreboot is now turned off so you should be able to read
the stop error.
"DeepDarkNews" wrote:
| Thanks but no joy.
| Any other ideas?
Thanks for this Dave. Your advice is welcome, but I think we're now into
tech territory and I'll hire some human help.
With appreciation
hap
news:uHx9UAnKFHA.1528@TK2MSFTNGP09.phx.gbl...
> then navigate etc
OK
Regards,
| With appreciation
| hap
