Pros: In addition to my 1st review on 1/12/07, this board has been rock stable. Not one single hiccup or crash has occurred.
Cons: However, I did find a DANGEROUS bug w/the BIOS: as long as you're in the BIOS menu, the CPU temperature rises like crazy(about 2 degrees per minute)! As if something is torturing the CPU. At first I thought it was a software glitch w/the hardware monitor, but the heat sink WAS getting hotter by the minute when I touched it. I really wanted to see what would finally happen but wouldn't dare to damage my core2duo, so I quickly exited the BIOS & booted into windows, that's when the CPU started to cool down. I tried different versions of the BIOS @ intel's website & found all of them have this issue! Especially the newest one(1649), which still didn't fix the problem & has a new bug, you gotta press the power button twice to turn the system on 'cause the BIOS shuts the system down the 1st time you turn it on!
Other Thoughts: I found the 1618 BIOS to be the least "bugged" version(still has the temperature issue though). While this problem doesn't affect normal usage, it can be annoying or dangerous when tweaking the BIOS. Still a good board though, but I'm not buy another intel mobo.
