I currently have an Audigy 2 ZS. Ive been using my onboard audio since I installed vista since creative is sucking at producing optimized vista drivers. However, I've heard that are some non-creative cards that are fully functional with vista. Anyone know which cards these are? Thanks!
I bought vista, im gonna use it. Yes, the audigy 2 has beta drivers, or those "new" drivers which are just re-released beta drivers, so its not fully functional. Ninja: what card is this? Please tell me!
So I guess I'll ask again:
What are some fully functional, vista compatible sound cards? (that arent made by creative)
Thanks for your relevant responses!
Use it, but you should knew before you bought Vista that Audigy and X-Fi cards have so many compatibility probles with it. Check around the forums to see what Im talking about. And not only here, most forums have at least 1 person like you in the same situation.
And to answer your question
Why dont you go to newegg and check each and every sound card review?
Wouldnt that save you time instead of waiting for people to come and answer?
I already found that auzentech has some decent cards. Apparently, though, they arent much better than the Audigy 2 ZG lines of cards. Anyone else have personal experience with awesome cards on vista? tahnks
I have an Audigy 2 ZS and it sounds fine to me with Vista Home Premium. Movies, games, and iTunes sound fine with my Logitech 5.1 Z5500's. (They also seem ok with my old 2.1 X-230's.)
I'm using vista and a x-fi fatality, the only problem with the drivers is they don't have the option to customize your eax effects yet, just the presets.... but give it time.
