I'm having some problems with the new built. Here are the list
1) It does this thing where it freezes for 1 or 2 secs then comes back while I'm playing a game.
2) When I have to use the reset button, it freezes at the post screen before it can detect the HDD. Then I have to power it down and power it up to get it working again.
3) When I enter Stand-By mode the fan gets really loud and stays loud until I get out of Stand-by mode, which it shouldn't.
4) This problem just happened recently. The computer crashed while I was watching something, and when I shut it down and turned it back on this problem appeared; The computer is slowing down at times now and you can hear and feel it slowing down at sporadic intervals during anything that I do. I can't pinpoint whats the cause of this. PLEASE HELP. Can't afford to re-format, I gone too far.
Should I install some softwares to check what hardware component is giving me the 4th problem?
Even if you only know solution to one problem, please post it. It'll help me a lot.
