Direct Parallel Problem
Forum Windows XP : Windows XP General Discussion - Direct Parallel Problem
Archived from groups: microsoft.public.windowsxp.basics (More info?)
A Direct Parallel connection between a XP Home and Win95 shows "connected"
on the HOST (Win 95). However, the GUEST (XP) cannot see any files on the
Win95. Connection is with a new Direct Parallel cable.
Any ideas are appreciated - thanks, Cecil
Sponsored Links
Probably because Win95 files are FAT32 and XP is NTFS. You'll need
a cross-over cable RJ-45, get it from Radio Shack if both PCs have the
connection port. Then go to Start>All Programs>Accessories>System Tools>
Files and Settings Transfer Wizard.
Reply to Byte
In news:589B71B6-B86A-435E-834E-8045E7BA78DA@microsoft.com,
Byte <Byte@discussions.microsoft.com> typed:
No, original Windows 95 supported only FAT16 and FAT12. Only with
OSR2 was FAT32 support added.
> and XP is NTFS.
No, XP supports all of these files system--not just NTFS, but
also FAT32, FAT16, and FAT12. Windows XP has no problem seing any
file system on a Windows 95 computer.
Windows 98 can't see an NTFS drive if it's attached locally, but
even that doesn't matter over a network. Over a network the file
system doesn't matter, since only the data is transferred, not
the underlying file system.
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
> You'll need
> have the
> Tools> Files and Settings Transfer Wizard.
>> "connected" on the HOST (Win 95). However, the GUEST (XP)
>> cannot see
>> any files on the Win95. Connection is with a new Direct
>> Parallel
>> cable.
Reply to Anonymous
In news:%238l7JGxLFHA.2132@TK2MSFTNGP14.phx.gbl,
Ken Blake <kblake@this.is.an.invalid.domain> typed:
> with
>> and XP is NTFS.
> any
> Windows 98
Sorry, typo. That should have been "Windows 95."
> file
>> You'll need
>> have the
>>> shows
>>> cannot see
>>> Parallel
>>> cable.
Reply to Anonymous
The issue of FAT and NTFS would not effect files viewed over a network. It
is a local system issue only (think dual boot system).
Sharon F
MS-MVP ~ Windows Shell/User
In memory of our dear friend, MVP Alex Nichol
Reply to Anonymous
The default workgroup name is different in Win95 than XP Home. Rename
workgroup so that it is the same on both systems (system properties>
computer name) and try again.
Since Win95 is the host, there may be some network protocol issues. Repost
this question in the windowsxp.network_web newsgroup if you need further
assistance.
Sharon F
Reply to Anonymous
Did you remember to share the hard drive on the 95 PC?
Cari (MS-MVP) Windows Client - Printing & Imaging
www.coribright.com
In Loving Memory of our dear friend Alex Nichol MVP
"Cecil Kearney" <Cecil_Kearney@msn.com> wrote in message
news:eK4Rr9uLFHA.1300@TK2MSFTNGP10.phx.gbl...
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Direct Parallel Problem
There are 748 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
