Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > motherboard 8 pin cpu power connector
Forum Graphic & Displays : Graphics Cards - motherboard 8 pin cpu power connector
When did the motherboards begin using the 8 pin cpu connector instead of the 4? What is the difference? Is different power supplied or just more? Also can you hook up a 4 pin to the 8 pin with an adapter without hurting anything?
Sponsored Links
Because you can supply more power down 8 pins, or supply power from more than one rail.
Its the same voltage, just more max total ampage.
Yeah you can use a 4->8 pin adaptor, or just connect the 4 pin on its own.
130W is the typical (not max) TDP of a QX6700. Thats over 10 Amps at 12v.
Thats quite a lot of power for the thin little wires on a PSU.
Overclock that QX6700 and it will easily be using 20 Amps of power or more at load. At that point you'd definately want to be connected with all 8 wires (half of these will be earths, so thats 5 Amps per +12v wire).
On the other hand, most of us are running dual core conroes with a 65w TDP, or about 5.5 Amps total. As long as you are not overclocking, or at least not overclocking much, this should be ok.
Reply to darkstar782
There are 1064 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
