Archived from groups: microsoft.public.win2000.setup_deployment (
More info?)
Thanks Sean, I'll look into these things. Due to security, I can't
move PCs or servers, and different departments operate switches
between sites so it might be port related. There is NO video after
hittig F12. There are also multiple images, so adding a new one won't
help. RISETUP -CHECK came up as all fine.
On Fri, 7 May 2004 16:25:26 -0400, "Sean Dwyer[MSFT]"
<sdwyer@online.microsoft.com> wrote:
>Hi Brad:
>I've not seen anything about the latest round of patches breaking RIS.
>As a test you may want to put down another image on the RIS server and see
>if that one deploys successfully.
>You can do this by running Start/Run and then RISETUP -ADD. You may also
>want to run an RISETUP -CHECK to have the RIS components examined and fix if
>needed.
>There is a video issue that are addressed in the two articles below. You may
>want to investigate whether or not these fixes would address the issue
>you're seeing.
>Windows 2K
>317863 A RIS Client Installation May Hang at the "Setup Is Starting Windows
>http://support.microsoft.com/?id=317863
>Xp images
>319111 Windows XP RIS Client Loses Video or Stops Responding While "Starting
>http://support.microsoft.com/?id=319111
>If when you hit F12 on the Client machine - the WELCOME.OSC screen NEVER
>comes up, try to simplify the connection between the client and the RIS
>server. Ideally, try putting the client on the same local subnet as the RIS
>server. If the client is requiring connections and communications through a
>switch or router, make sure the required ports have not been closed by
>either the patches or by another administrator.
>832017 Port Requirements for the Microsoft Windows Server System
>http://support.microsoft.com/?id=832017
>Remote Installation
>You can use
>the Remote Installation system service to install Windows 2000, Windows XP,
>and Windows Server 2003 on Pre-Boot eXecution Environment (PXE) remote
>boot-enabled client computers. The Boot Information Negotiation Layer (BINL)
>service, the primary component of Remote Installation Server (RIS), answers
>PXE client requests, checks Active Directory for client validation, and
>passes client information to and from the server. The BINL service is
>installed when you either add the RIS component from Add/Remove Windows
>Components, or select it when you initially install the operating system.
>System service name: "BINLSVC"
>| Application protocol | Protocol | Ports |
>| BINL | UDP | 4011 |
>Trivial FTP Daemon
>The Trivial FTP Daemon system service does not require a user name or a
>password and is an integral part of RIS. The Trivial FTP Daemon service
>implements support for the Trivial FTP Protocol (TFTP) that is defined by
>the following RFCs:
> RFC 1350 - TFTP
> RFC 2347 - Option extension
> RFC 2348 - Block size option
> RFC 2349 - Timeout interval, and transfer size options
>TFTP is a file transfer protocol that is designed to support diskless boot
>environments. TFTP daemons listen on UDP port 69 but respond from a randomly
>allocated high port. Therefore, when you enable this port, the TFTP service
>can receive incoming TFTP requests, but enabling it does not allow the
>selected server to respond to those requests. You must configure the
>selected server to respond from port 69 to allow it to respond to inbound
>TFTP requests.
>System service name: "tftpd"
>| TFTP | UDP | 69 |
>If this information doesn't wind up helping you figure out what's going on,
>please contact our Platforms Setup team via the phone and get a case
>created. We'll be glad to assist you in tracking down what the problem is.
