Motherboard: Asus A8V-E Deluxe
Hi, just joined the forums. First-time poster, long-time Asus motherboard and Corsair memory user.
This is my second or third custom built computer (not built by me). This one is from March/April 2005. Shortly thereafter I noticed this loud whirring sound from the computer, and something that sounded like if you held a piece of looseleaf paper in the fan blades. I ignored everything and eventually they stopped. I also remember losing some system speed at that time. Again, I ignored all of this.
A couple of days ago I decided I wanted to get more memory, so I opened up the computer to refresh my memory on what I had in there, and to spray some compressed air around to remove dust. I re-remembered that the fan wasn't moving! Again, this is the small fan on the motherboard, not the massive (larger than my hand) one sitting on what I think is my processor.
I messed around with the small fan and removed the top plate (removed four screws) to see if I could learn something. Whatever I just did, reactivated the noise that sounds like something knocking into some fan blades. What could it be? Could it be the video card fan? It can't be the small fan because that isn't moving, so I have two problems in there, wtf.
So my questions are:
1) What does the small fan do?
2) Is it possible that it's not moving because the plate that's on top of it is on too tight?
3) Any dangers in trying to run my system with that plate removed?
4) Any ideas as to what the sound is that sounds like a wire constantly hitting some fan blades (can't find the source!)?
I'm planning on getting this professionally looked at after having a talk with Asus's RMA department on Monday. Any help is appreciated, thanks!
- action
- action
