power and cpu loads
Hello all,
Everytime my CPU gets loaded about 60%, all voltages as reported by gigbyte utility will start to drop...at 80% loads
12V becomes 11.0
3.3V becomes 2.9
Vcore becomes 1.1
CPUvid becomes 1.07
Also the HS fan rpm will drop to 1200-1250 and over heat buzzer will go on..
I assume the PSU is not enough..and therefore much be changed..or secondary PSU installed to ease some load on main psu..
what ya'll say??
2 answers Last reply
More about power loads
  1. that's a sign of cheap or worn out psu - that's classic signs of el cheapo psu
    a good psu the voltage goes up very slightly with increased demand
    secondary psu's are a bad idea if your talking a 5.25" slide in those are bad news -DO NOT USE A 5.25" AUX PSU!
    if your talling 2 125w xeons and 8 hard drives and 2 gtxs and your 1000w is stressed and your going to add a 600 - in your giant server box made for 2 full size psu's - thats ok!
  2. when i say aux psu..i mean a regular PSU modded to run stand alone and controlled by relay for powering the fans, HDD's and stuff
    I know power draw for this pc is quite high..high quality PSU goes up in cost with rated wattage and in terms of economy, PSU quality doesn't matter for powering fans..
Power Supplies CPUs Power Components
