Coolmax 600W dual rail 12v power supply w/120mm internal fan & built in 3 speed fan controller. SLI support, SATA support, no modular cables, or fancy sleeving tho 8(. Nice thick finish, with glossy paint. 19amps x 2 is the best part, and its' also high-efficiency rated.
I'd rate this at about a 7.5 or 8 out of 10. There are a couple things that could/would be better, but some say the modular connectors degrade performance & cable sleeving is just an aesthetic thing. A cheap sleeve & connector kit on this PSU and it could be stunning in appearance.
A lit fan could/would have been nice, but most of those usually suck as fans - so is that even really a tradeoff? A clear panel or 3 would/could be cool, but I could mod that in..
A remote panel for the fan controller switch would/could be a good thing, but that would also push up the price. Reaching behind the case, with my external 120mm (for the internal 120mm radiator) fan can be dicey! That fan is moving! Anyways.. The switch is nice, but only once in a while does it get changed.
